Question about Dryers
Gas dryer stops flame
Gas dryer flame turns 0n for 5sec than goes off
  • 1 more comment
  • Moebius Jan 02, 2009
    The flame comes on for 5-10 seconds on my Kenmore Series 700. About 45-50 seconds later it will burn again for 6-8 seconds. This goes on for nearly 3 hours before the load is dry. The vent is clear. I'm guessing it must be one of the two thermostats. Either the high-limit one on the burner tube or the internal-bias on the vent near the fuse. Anyone have suggestions on how to figure this out? Or is it something else?
  • Moebius May 11, 2010
    I forgot I attached to another person's initial post. Johnnyboy32's solution may apply to Camali77's problem.
    As I mentioned there is nothing blocking the exhaust/vent. The venting is totally clear. I've tried running the dryer with no exhaust tube connected to the back of the dryer and I still get the same results.
  • 91 Answers
CHECK EXHAUST HOSE KINKED ,, REMOVE HOSE FROM BACK OF DRYER NOW SEE FLAME SHOULD STAY ON ALOT LONGER ,,,BUT REMEMBER ,ITS CARBON MONIXIDE IF THAT PROBLEM CLEAN OUT EXHAUST ,,
Posted on Jan 03, 2009
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Hi i have a whirpool gas dryer that all works fine but after about five minutes the heat will stop and it will just blow cool air. I can stop it and restart and everything starts and works fine and after...
The gas valve coils are closing the valve or the flame sensor is defective. The coils are the most common problem.
There are 2 on top of the gas valve. Turn off the gas and power. Remove the front panel by opening the top lid and then remove the screws from inside the front panel in the top right and left corners.
Nov 09, 2009 | Whirlpool Dryers
Mdg 4000aww turns on and heats when started. runs for 5 five minutes then flame goes out. ignitor glows but no flame. one minute later dryer still running ignitor glows, no flame. this repaets until turned...
Either the venting needs cleaned or the coils on the gas valve are bad. Unhook the venting from the back of the unit and run. If works ok then clean venting. If you still have the problem, replace the two coils on top of the gas valve.
Sep 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas Dryer model 110-77974110
the coils on your gas valve are going out , this is why it will work at first and stop , the coils heat up and wont open the valve again after they are heated.
I thought they were some what cheaper than they are now but still not too bad. you can try this part number search on ebay for the best price I can find.
279137 coil kit
Phil
Jun 11, 2009 | Kenmore 74602 Gas Dryer
Dryer will turn and start heating then goes out...it's gas
Coil valves need to be replaced.they are the 2 black rounded on top of module where gas line goes into.aout 35 bucks for both.
Mar 28, 2009 | Kenmore 74602 Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Flame shuts off after five seconds
HI! I BELIEVE THE PROBLEM YOU ARE HAVING IS CAUSED BY A PART CALLED THE THERMOCOUPLER. THIS IS A SAFETY DEVICE THAT SHUTS OFF THE GAS IF THE FLAME GOES OUT, BUT IT NEEDS HEAT TO MAINTAIN THE PROPER CIRCUIT. THIS MEANS THAT THE THERMOCOUPLER IS BAD AND NOT HOLDING THE GAS VALVE OPEN AS IT SHOULD. IT IS A SMALL THIN ROD TYPE THING THAT WILL BE VERY CLOSE TO THE PILOT OR IGNITER AND IT HAS TO FUNCTION PROPERLY TO ALLOW THE GAS TO CONTINUE TO FLOW. WHAT IT IS DOING IS GETTING JUST WARM ENOUGH TO OPEN THE GAS VALVE, BUT THEN THE IGNITER STOPS AND THE BAD THERMOCOUPLER COOLS AND TURNS YOUR GAS OFF. YOU NEED TO REPLACE THE THERMOCOUPLER AND YOU SHOULD BE BACK TO WARM CLOTHES IN NO TIME. HOPE THIS HELPS YOU. ANY QUESTIONS, JUST REPLY AND I'LL HELP MORE.
ARCLIGHT1217
Nov 02, 2008 | Maytag MDG2706A Gas Dryer
Gas dryer won't dry
kbaker926:
This is a purchased product manufactured by another manufacturer for Sear.
It sounds as if have a flame sensor or a thermostat opening turning power off to the burner thus flame goes out.
If you are able to to catch the dryer just as it shuts off you would be able to do some ohms readings to find out what components have opened in the curcuit.
((((This is only if you are able to properly use and read a Volt-Ohm meter))))
These checks should only be done with the Electrical supply turned OFF and at least one wire disconnected from the component being tested
Woodychoppers
Oct 31, 2008 | Kenmore 75944 Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
165 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
