Question about Ovens
My defy slimline emsg does not work we moved in to an new house and tried to bake something one day and it just doesn work the lights of the oven works but only the timer lights how do I get my oven to work plz help
5 Suggested Answers
Powerman
  • 68 Answers
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Posted on Feb 07, 2008
only the temp. down button won't work on my ge profile oven
Posted on Oct 01, 2008
  • 44 Answers
SOURCE: Smeg sp9000x.2 double oven - no heat from top oven
hi
the changes are if the fan is turning and light is on then the element around the fan will need replacing hope this helps
regards dan
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: Fan works but oven doesnt get hot
One of the switches looks to be a 5 position switch. 0=off, 1=Light, 2=fan
Posted on Sep 23, 2010
Defy slimline eyelevel oven installed in cupboard.
Assuming it is an electric built in or built under oven, these are commonly fitted into a dedicated cupboard (oven housing) that matches the other kitchen units and typically little or no facility for ventilation is provided.
Electric ovens are usually so well insulated and covered with reflective foil the need for ventilation is minimal, especially when a standard size oven is fitted into the correct standard sized housing as it will provide an air-space of an inch or more all around.
It can be expected the housing near the top of the oven will become warm after a while and the shelf above likely to become warm enough to soften a candle but if it gets hot enough to actually melt a candle I think that is rather too hot. The addition of additional insulation and reflective material should improve matters greatly.
I suggest you approach the guy who fitted the oven if it was professionally fitted. It would have been his responsibility to only fit a suitable appliance and if additional ventilation was required he should have advised you.
I believe I have seen some oven housings with a slim grille over the oven and it is probable there would have also been a slot cut at the rear and perhaps a short piece of trunking to carry warm air away from the space directly above the oven.
Mar 30, 2016 | Ovens
WHERE CAN I GET A NEW OVEN KNOB (DIAL) FOR MY DEFY SLIMLINE OVEN. HAVE BEEN TOLD THAT THEY NO LONGER MAKE THEM.
SADLY if they no longer make that type you might have to try and glue the old one back together ..we can not produce something that does not exist
Oct 05, 2015 | Ovens
I have recently moved into a new house and can't get the oven to work. I was hoping to get a manual for the wall oven and see if this information will solve my problem. It is a 1993 model EVBS3193...
So you have moved to a new house. I am assumeing that the Oven worked fine at the old house. I am also assumeing that you have plugged the Oven into your new house and that is when you noticed that it was not working.
If this is the case then the problem may be that the Breaker in the Electrical Sevice Panel of the new house is off. You need to reset the breaker and the Oven should then work.
Jun 12, 2011 | Ovens
I HAVE A GENERAL ELECTRIC (WALL) OVEN MODEL #JKP13G.. WHEN IO TRY TO PREHEAT THE OVEN TO BAKE SOMETHING IT LIGHTS UP TO ONLY ABOUT 100 DEGREES (BUT DOESN'T GET HOT AT ALL( AND THENIT JUST CUTS OFF. ...
if the clock is cutting out on you it sounds like the computer board or clock assy. same thing is bad but this oven is to old and you can't get the board anymore,it's to old and they don't make parts for it anymore,get a new oven
Nov 08, 2017 | Ovens
My oven will not light the lighter gets red hot but it will not light the gas. i haved moved the wires after i unpluged it and pluged it back in and it work for a bout 3 days now it will not so what do i...
even though the ignitor is glowing it doesn't mean it's good.it works by amps,it takes 3.2 amps for the ignitor to glow and open the gas valve,try this,put it on broil,if the broil ignites then change out the bake ignitor,
May 11, 2011 | Frigidaire Ovens
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
The clock started flashing as if the power went out. Then when we tried to
The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle)
May 22, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
