Bulb still good but its saying it needs replaced
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Not knowing the brand or model (not listed here) many sets will flash this when lamp has reached a certain number of hours and many sets when lamp is replaced (see owner manual) the LAMP TIMER has to be reset to start the process over again---usual life is 2,000 hours or 2 years.
Posted on Oct 24, 2012
Replace turn signal bulb
Is it the correct bulb. This one is likely a single element bulb, did you maybe get a dual element bulb, is the bulb installed correctly if it is a dual element bulb and socket. Have you checked that the new bulb is in fact a good bulb??? If none of the above you will need to start wire diagnosis. Are there ant DTCs set?? You do not say what year it is which severely limits any reasonable chance of particular diagnois.
May 04, 2014 | Harley Davidson FLSTF - FLSTFI Fat Boy...
I need to replace the bulb. Do I need to order the bulb only or bulb+housing. where is the bulb located on the back of tv? Thanks for the help
If you are looking at the back of the TV look on the left hand side to see if there is a access panel on that side of the TV - open it up and you will see the light bulb housing - take it out and look to determine whether you think you can replace the bulb by yourself or if you need assistance - I will say this most of the LGs are not soldered on they are put on using a small nut and they are easy to replace - 1 note is to order just the bubl if you think you can replace it yourself but DO NOT remove the bad bulb from housing until you get the new bulb so you can see how to hook up the new bulb :-) plus it usually takes about a week to get the new bulb in and sometimes people tend to forget how things were taken apart :-) Good Luck you will save money if you order only the bulb!
Thanks,
MC
Oct 28, 2010 | LG RU-52SZ51D 52" Rear Projection...
It says we need a bulb. Serial # ATMV 28 0276,
sp-lamp-019, but good luck finding one under $500.
Dec 14, 2009 | InFocus ScreenPlay 4805 Multimedia...
My headlights will not light up. the fuses in the
it's likely the headlight bulbs themselves need replacement.if high beams work but not low beams,suspect bulbs.if neither work,suspect switch,then wiring.
Oct 18, 2009 | 2004 Volvo XC90
Right rear turn signal doesn't work and the blinker light on the inside is blinking fast, what do you recommend? It does work on the right hand side rear view mirror though
the bulb at the taillight has blown. Replace the bulb. The fast blink is the systems way of saying "Hey, we need a repair here!!"
Oct 09, 2009 | 2004 Ford F150
Thought the bulb was bad, replaced and still no light.
where did you get the lamp from? if you got it from a reputable dealer, then i'd say the ballast is bad and needs replacing. if you got it from "bob's bulbs", then it may be the lamp. but the only way to test it is to put it in a known good projector.
Sep 11, 2009 | Sanyo PLC XU48 Multimedia Projector
Projector turns on but no light or image from lens.
The bulbs do not always look broken when dead. You say it is used often. The life of a bulb is around 1400 hours I believe. This normally equates to a year or two depending on your usage levels. Did you notice your image getting dimmer in the months before it stopped working? This would be a good sign it was in need of replacement. Are the lights flashing very rapidly or blinking slowly? If they are flashing very rapidly this indicated the bulb will not fire and needs replacing.
Jan 16, 2009 | Dwin TransVision 3 Plus Multimedia...
Says bulb has to be replace.
If your Tv is less than a year old you want to get ahold of Mithubisi NOW! There are two upgrades if you can call them that that adress the overheating and blocked airflow, And if the lamp needs replaced I'm sure you would rather have Mitshubishi pay for the 350.00 lamp than you
Feb 22, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
