Question about Yamaha YST-MS30 Computer Speakers
YAMAHA YST-MS30 REAR INPUT 1 & 2 JACKS OR ADAPTER for SOUND
I need the 1 & 2 input jacks or adaper that fit into the computer so i will have sound.
5 Suggested Answers
Open SKy
  • 620 Answers
SOURCE: input cable
Hi Eric, you can use Black Color Cable (1.8 m) with 3.5 mm Stereo Mini Jack x 1 pc,
1.8 m (6 ft.) Cable with RCA Pin Jack, and 8-pcs No Skid Pads or you contac support for your particular speakers, considering is a good brand, here, http://www.yamaha.co.jp/english/product/av/products/pc/m8.html
there you may found your cable.
Carl
Posted on Nov 06, 2007
xalint1
  • 152 Answers
SOURCE: How do I hook up my 2 speakers and subwolfer to my computer.
I have found the link for your instructions www2.yamaha.co.jp/manual/pdf/av/english/pcS/YST-MSW10.pdf
Posted on Aug 12, 2008
SOURCE: Missing the input 1 and 2 cables
My son found the missing cables.
Thanks for you offer.
Dennis
Posted on Jan 27, 2009
dickgs
  • 22 Answers
SOURCE: I NEED AN AC ADAPTER FOR MY YAMAHA YST-M7 POWERED
Check this... its the nearest specs I've found... Good Luck.
http://cgi.ebay.com/AC-DC-Adapter-110-220VAC-to-1-5-3-4-5-6-7-5-9-12VDC_W0QQitemZ200415259300QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9ae2aa4
Posted on Dec 12, 2009
Rear jacks
Connect the device with rear sockets, and select the input. As there is rear jacks to your TV AV-1 & AV-2 selection must be there. Enter into its Menu option, surf through, come to input selection window. and select proper selection here. Switch ON both the devices before selecting inputs. When correct input selection have been done, the logo of your external device will appear on screen.
May 26, 2012 | Samsung TCD1382 13" TV
Could you use the Bose 901 series VI for a pa system?
Actually that's where the bose 800 systems came from.
Old school jazz guys were using their 900 series turned backwards as a pa
Mar 31, 2017 | Music
My subwoofer only works at a very low volume, even with the bass turned all the way up on the subwoofer and on my computer.
You might need to get a different sound card and/or an amplifier, as the sound card on your computer may not be pushing enough amps to the system.
Aug 05, 2011 | Yamaha YST-MS30 Computer Speakers
Hp plasma ID5226N can get external audio input when in HDMI 2. I have a DVI to HDMI cable from my computer to TV, & manual says to hook the audio to the input jacks, but no sound comes out. I can use...
DVI cables are usually HDMI compatible. The downside is that DVI usually doesn't carry any audio. Your computer may need a specific audio card to transmit audio/video data from your DVI output to the HDMI input on the TV. You can find one at your local computer store and ask if it is compatible with your computer
I hope this helps...good luck
Jun 23, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
Dennis
Jan 26, 2009 | Yamaha YST-MS25 Computer Speakers
How do I connect a mac audio output to a yamaha sound projector?
NO!!! get a 3.5 male TRS to stereo RCAs to either the Aux input on the amp or the audio portion of the front A/V Aux. the audio jacks will be red and white.
Dec 04, 2008 | Yamaha Digital Sound Projector Home...
Converter of audio cassettes to CDs
Get a computer with an audio input or soundcard. Like a Mac with garageband and a soundcard. connect both with a male 1/8" to male 1/8" cable. Press play on the tape deck, record on the computer. Once done, edit and trim the beginning and end. Import to itunes. Create a playlist. Burn to cd. Simple.
Aug 28, 2008 | Audio Players & Recorders
Aug 12, 2008 | Yamaha YST-MSW10 Computer Speakers
Input cable
Carl
Nov 05, 2007 | Yamaha YST-M8 Computer Speakers
Open Questions:
Yamaha YST-MS30 Computer Speakers Logo
47 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
