Question about Home
Vitra S50 Soft closing problem works loose
Continually working loose
2 Suggested Answers
radar001
  • 1051 Answers
SOURCE: loose toilet seat
If the screws don't tighten the either the screw threads are stripped or the attachment nut is stripped. Take the screw and nut to any hmoe repair center and get new ones. remember don't over-tighten then screws as this will crack the unit.
Posted on Feb 11, 2010
2008 Suzuki s50 poppong and eventually dies. Help!!
Hi, Wendy and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. A failed fuel pump, pressure regulator and or fuel injectors.
16. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
17. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
S50 stalling and not restarting Page 2
Suzuki VL800 Service Manual
OEM parts for Suzuki
Suzuki VL800 Owner Manual
Oct 06, 2016 | Suzuki Motorcycles
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
When i turn my satnav on open page comes on and then it showes a picture of satnav charging from a laptop and will not go to anything else can u help me please thanks graham
Hi Graham,I had exactly the same problem with my Nav Man S50. After the icon of the lap top my screen went blank. I updated it via the soft ware provided but no updates were available. In fact the problem turned out to be the on/off switch. Although it was glowing red it was not charging. I simply placed a pen into the switch and it worked.
Hope this will help.
Maureen
Sep 04, 2011 | Navman S50 Portable GPS Automobile...
My vitra soft close toilet seat doesn't soft close anymore?
Chances are that the friction washers that control the closure rate are worn out. Most of these are not replaceable so you will need to get a new one. Thanks
Nov 18, 2010 | Home
Loose toilet seat
Feb 11, 2010 | Toto Drake ADA Compliant Toilet with...
My coolpix s50 won't turn on. to my knowledge it hasn't come into contact with any water or liquids and the battery is fully charged. is this something i can fix myself or do i need to send it to nikon?
Happened to me before. Suggest you try and check the battery cover lid, close it properly because there is a sensor underneath there, where it will turn off the camera if the lid is open. Try it several time and ways. Hope this might help, it does to me and now my S50 is working perfectly... cheers!!
Sep 29, 2009 | Nikon Coolpix S50 Digital Camera
Canon powershot S50: Sliding door stuck.
this can happen,gently tap the door(GENTLY) may loosen it works on my a70
Aug 18, 2009 | Canon PowerShot S50 Digital Camera
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
Sliding Lens Door Problem -- Canon S50
I had the same problem with a S50, where the lens door would not operate properly and would not open enough to cause the camera to activate. I took it apart and found that there are two small gears that keep the door on track, one had split in half and jammed the mechanism. They were white plastic, perhaps nylon? I found another S50 on ebay with broken electronics but a working lens door and took parts from it to fix my system. Getting the tiny gear in place was tricky as there are several springs used to activate the camera on switch.
Jan 18, 2009 | Canon PowerShot S50 Digital Camera
Home Logo
24 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
