Question about Bosch Microwave Ovens
Bosch hmt85ml53b microwave keeps stopping after 10 seconds, tried different settings no luck
Tried reset- different program - manual
MicrowaveSvc
  • 9047 Answers
SOURCE: panasonic nn-s560wf
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Posted on Oct 22, 2007
Illeagle
  • 525 Answers
SOURCE: Panasonic NN-T994SF 1250 watt countertop microwave stopping
From my research, this sounds like a fairly new model. Consult your user's manual to see if this is a user, or common issue. If nothing is descibed then I would seek possible warranty service, or dealer replacement
Posted on Jun 03, 2008
BIKER T
  • 909 Answers
SOURCE: Kenmore microwave (2 y/o) will stop soon after you hit start.
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
Posted on Sep 17, 2009
heatman101
  • 43501 Answers
SOURCE: bosch HMT8655GB, after being used no heat and cuts out at 22 secs
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
e6tuwe
Posted on Sep 30, 2010
vetteman3002
  • 2299 Answers
SOURCE: I have a JE1860 GE
A lot of times the error can be cleared by unplugging the microwave and leaving it unplugged for about 5 minutes. If this doesn't work then the actual sensor is probably gone bad. If you want the part number and price of the sensor, let me know and I will look it up for you. But the sensor should be changed by a trained technician. But hopefully, unplugging the microwave will solve this problem.
Posted on Nov 29, 2010
Microwave stops after 59 seconds
Check that a "favourite" setting has not been selected. The unit may think that is the time that you want to cook. Im not sure about your model but see if there is any clear or cancel buttons to clear any pre programmed selections. If not, unplug the machine for 15 minutes to reset the controller and try it again.
Nov 25, 2013 | Electrolux Microwave Ovens
Bosch hmt8656gb microwave doesn't always start
The problem is in the keypad control board and usually means it must be replaced to fix the problem, and the part alone is expensive.
Jun 02, 2012 | Bosch HMT8656GB Microwave Oven
Microwave doesn't start but the interior light goes on when you hit the start button
Hello
Remove the plug from the wall outlet and wait about 10 seconds before re-inserting it. The plug must be firmly inserted to transfer electricity to the appliance.
Open your home's circuit breaker box and reset the breaker if it has tripped and is set to the "Off" position. Simply slide the breaker over to the "On" position to fix a breaker that has tripped.
Plug a different appliance into the same outlet to make sure the outlet you are using is functional. Plug the microwave into a different outlet to see if this yields different results.
Press on the microwave door to ensure it is completely closed. The microwave will not function until the door is fully shut.
Press the "Start" pad on the display panel after setting the time. Failing to press this will result in the microwave not knowing that it should start.
Press the "Stop/Reset" pad on the panel if a program different from the program you want to run has already been entered into the system.
Press the "Clock" pad three times to turn off the demo mode. The demo mode will not allow the appliance to turn on and cook as it should.
Oct 04, 2011 | Microwave Ovens
The light inside goes on but the microwave doesn't
My Bosch microwave (built in HMB5050 has stopped heating all of a sudden. Everything else appears to work fine but it does not heat. What is the problem?
I have the same issue, plus mine shuts down after 30 seconds. There are a few other similar issues on here, with solutions including unplugging it for 10 seconds, replacing a fuse, and replacing half the internals. Please post your fix if you find one!
Jul 28, 2011 | Bosch 500 HMB5050 Microwave Oven
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
The microwave stops after 59 seconds.
hello,
what this means is that the timing of your oven have been program on 59 seconds mistakenly
what you need to do to correct this problem is that you will have to reprogram the timing by resetting the time program on it by clicking on the setting button and type in the new timer with this the problem is solve
Good luck and thanks for using fixya.
May 29, 2010 | Sharp R-1480 Microwave Oven
Jun 03, 2008 | Panasonic NN-T994SF Microwave Oven
Vent fan runs intermittently, starts on and off regularily
I don't have the manual but there should be a temperature setting for the fan to come on.
Jun 23, 2007 | Bosch HMV9305 Microwave Oven
Microwave Ovens Logo
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
