Question about Refrigerators
I have a Maytag mfi2569veb2 model - I followed instructions to defrost and allow to drain but this issue keeps recurring within a few days- how to I make sure that it is fixed correctly after fully deicing with hair dryer?
2 Suggested Answers
SOURCE: freezer icing up
I changed the defrost thermostat and it solved the problem.
Posted on Apr 07, 2009
Ice build-up on the bottom of the freezer drawer
Water on the freezer floor has only two sources, 1) ice maker overflow/leak, or 2) defrost drain plugged. For the first you can turn off the ice maker and shut off the supply water for a few days to see if the problem recurs. If this is the problem determine if the water fill valve leaks or the ice maker is the problem and replace the offender. For the second, thaw out and clear all the ice, paying special attention to the drain located under the freezer (cooling) coil. Then clear the blockage from the drain tube. BE CAREFUL AND DO NOT USE WIRE OR SHARP ITEMS as this can pierce a hole in the drain requiring replacement, not something you want to do or pay for. A turkey baster and hot water are useful tools to flush out the blockage allowing water to drain freely into the defrost drain pan under the refrigerator.
Sep 12, 2014 | Refrigerators
Freezer coil iced up how do put through manaul defrost srs536np
It is probably the timer for defrost that has gone out... some models allow for manual operation of the timer with a large, flat-blade screwdriver it is in the front-center "ceiling" of the refrigerator compartment. The hole is the access for manual turning of the timer. Turn it clockwise slowly until it clicks. Locate the drain tube & if the problem is the timer, water will start draining from the tube within a few minutes. If it is very iced up, it may take 45 minutes to defrost. Then turn the timer a half-turn or so to restart fridge. If you choose to replace the timer yourself, you'll need to manually defrost every day or two, depending on how many times & how long door is open, until new timer arrives.
Oct 03, 2011 | Refrigerators
I have a Maytag side by side refridge Model # MSD 2436GRW The refirdge side does not feel like it is cooling properly- I have had to move the dial up tp 8-9
There are many different ways a refrigerator will do this. But I will focus on the most likely and that will be either the 68233-2 Defrost Timer or the=> 61005989 Auto Damper Click Here=> MSD2436GRW_Controls and in that photo you will see the location's 13 and 8. Here are the instructions for testing the auto damper=> 61005989 Auto Damper Test Instructions Look into the rear of your freezer and tell me if ice or a layer of frost is covering the rear panel. If yes try to turn the defrost timer clockwise slowly untill refrigerator stops or manually defrost with a hair dryer. If the refrigerator defrost after turning defrost timer then just replace timer. Refrigerator will usally take 25 minutes after that time the refrigerator does not come on simply turn th timer clockwise until it starts. If defrost is not the problem then it is time to test the auto damper. There are a few other test like testing the defrost heater= HERE Here is the freezer compartment parts breakdown=> MSD2436GRW_Freezer_Compartment and part 12 in that photo is the=> 61006116 Defrost Heater Assembly with Defrost Thermostat
I will be here on Fixya or Here if you have questions, Thanks Sea Breeze
If helpful please rate this solution.. Thank You
Jul 19, 2011 | Maytag Refrigerators
I have a top mount Kenmore refrigerator, model no. 106.60272990, serial no. EK2929089. It is about 10 years old and works fine except for one problem that has kept recurring every 2-3 months over the last...
hey barry I had the same problem and i recently broke down and called a repair service, the repair person installed a small aluminum piece he refered to as a heat probe, on the heater coil which is behind the back plate in the freezer, he claims this will solve the problem, evidently the water created in the defrost cycle freezes before it can get down the drain, thus the drain becomes blocked with ice, subsequent cycling of the heater for defrost causes more water and ice buildup and the water overflows through air ducts into the refridgerator, I would check at an appilance parts store for this part it cost $20, unfortunatley the total cost of the service call was $ 227, My gripe is this is an obvious flaw in design and should have beeen addressed by Kenmore, if you make a part to remedy a problem then its an admission of the problem! Good Luck!
May 27, 2011 | Kenmore Top Freezer Refrigerator
I have a magic chef fridge that the coil keeps
Good day,
The defrost system is made up of 3 parts. The timer, the defrost thermostat and the main heater.
The most common item to fail is the defrost thermostat which is clipped to the top of the cooling coil, located behind the rear panel in the feezer problem. It looks like this.
It can be tested with an ohm meter and should read zero ohms.
It must be tested while still cold. If allowed to warm up the test will fail. If it tests O.K. then the only item left is the main heater.
It will usually test at less than 35 ohms. If it test infinity, then it will have to be replaced.
It may be a single heater or a set of 2 but without the model number I cannot give you that information.
Jul 06, 2010 | Maytag Refrigerators
Drain in freezer plugs up
sometimes can be solved by loosely coiling a piece of solid copper wire around the defrost heating element and down into the drain a little. the radiant heat on the wire during defrost cycle may help keep the drain open
Mar 13, 2009 | GE Refrigerators
Water puddle under fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 28, 2008 | Maytag MSD2756GES Side by Side...
Maytag Model ERSW22A side by side fridge periodically leaks water at the front of the fridge. Water appears to come from inside the freezer compartment. This only happens every few days, or once a day...
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Apr 22, 2008 | Refrigerators
Leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Oct 28, 2007 | Refrigerators
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
