Question about Magicard Rio ID 2 Card Printer
Magicard rio pro error 1801 - Magicard Rio ID 2 Card Printer
3 Suggested Answers
  • 7 Answers
SOURCE: Magicard rio 2e, the printer needs to print the
The Rio 2E is a single side printer to print on both sides of the card you need a Tango 2E Printer.
Posted on Feb 17, 2010
hytas
  • 61 Answers
SOURCE: I'm looking for driver for Magicard Rio
http://www.ultramagicard.com/technical-support/printers/files/magicard_rio_driver_v6.01.exe
Posted on Jul 19, 2011
Yellow shadow
Hello Joseph,
Is it possible to print and scan your printer's built-in internal test card.
Then include a link to a good high resolution scan of the test card?
On the Rio, Rio 2, and Rio 2e, push the small button on the rear of the printer (with the lid closed, and dye film fitted). For the Rio Pro, on the front panel choose Menu -> Test Card - Yes (to confirm).
This will help identify the cause.
Exactly which model do you have? There were several Rio models. (the one in the picture is the original Rio). Later models were Rio 2, Rio 2e, and currently the Rio Pro.
Kind Regards,
MC
Apr 15, 2014 | Magicard Rio Card Printer
Flipper error
Hi There,
Only the Rio Pro model has a flipper fitted. If it is the Rio Pro, there will also be an error number at the end of the error (18:??).
Kind Regards,
MC.
Feb 25, 2014 | Magicard Rio Card Printer
Printing lines on cards
Hello Richard,
Sorry for the delay in replying to your request.
You may have already resolved your issue by now.
The advice below may help others with the same issue though.
In the case of a damaged (scratched) printhead, the lines always run along the cards longest length (landscape), and are always in exactly the same place.
They are normally White, and usually very thin (just a few pixels wide). You would also see the line on the used dye film too by unwinding some film from the take-up spool (at the front of the printer).
Sometimes in the case of older out-of warranty printers, it is easier / cheaper just to avoid that are of the card using the card design. The image can also be rotated 180 degrees in the driver's Printing Preferences. However, if the card design has a solid colour background, or the White line is in the centre of the card, printhead replacement may be the only option.
Depending on which Rio model you have (Rio, Rio 2, Rio2e, or Rio Pro), different printhead assemblies are available as a field replaceable unit. Part numbers are below;
Magicard Rio - FG/M9005-794
Magicard Rio 2 / Rio 2e - FG/M9006-630E
Magicard Rio Pro - FG/3652-0160
All are available from your local Magicard dealer / reseller.
Prevention is better than cure;
  • Replace the sticky cleaning roller in the cleaning cassette as regular as possible.
  • Only use good quality blank PVC card stock (no sharp edges, or burrs)
  • Clean the printer regularly using the appropriate cleaning kit;
    Rio, Rio 2, Rio 2e (Cleaning kit part number: M9005-761)
    Rio Pro - (Cleaning kit part number 3633-0053) *
    Rio Pro - (Sticky roller kit (5 rollers +metal shaft) - 3633-0054)*
    * A sticky cleaning roller is supplied with every new dye film
Kind Regards,
MC.
Dec 03, 2013 | Magicard Rio Card Printer
Error 24:06
cordial saludo.
somos Estatal de Seguridad Ltda tenemos Una Impresora magi card Rio- pro, Hace unos meses dejo de funcionar indicando el error 24:06 (al Darle la orden de impresi?n dice --alimentar Tarjeta y Ah? viene el error, la Tarjeta se Queda atascada justo Debajo del cabezal de impresion,
Aug 30, 2013 | Magicard Rio Pro Dual Sided Photo ID...
Magiccard Rio printer is giving error code 24:24
Error code 24:24 means that the sensors need to be replaced. This requires sending the printer back to MagiCard for them to replace the sensors.
Mar 01, 2013 | Magicard Rio Card Printer
I have a Magicard Rio I keep getting the error message card jam error 02:12 yet there is no card jam if i put a card in the back it ejects it correctly help
Hello Colin,
I'm not sure how old your printer is, but I suspect this is caused by a loose connection on the front card sensor (especially if the error occurs when initialising). If there is a loose connection, the card sensor always shows as blocked (hence the error 02:12). I guess this is a Rio 2e and not a Rio 2 model.
Send us an email to;
support@magicard.com
Make sure you quote the printer's serial number in the email.
I can send you some detailed instructions for confirming this is the problem, and also suggestions for repairing the printer.
Regards,
MC.
Nov 16, 2012 | Magicard Rio ID 2 Card Printer
Rio pro error code 24:04
Hi Magicard Rio Pro message:
"General Error : Contact technical support, quoting error 24:04".
Somebody help me?
Jun 28, 2012 | Magicard Rio ID 2 Card Printer
Card jam please clear printer
Hi Imran,
I realise you probably resolved this issue a long time ago, but this may help others with the same problem (Card Jam on Rio Pro / Enduro / Enduro+).
Immediately after the Card Jam - Please clear printer mechanism, there should be an error number. All card jam errors begin with 06:??. Most common would be Card Jam 06:05.
This error means that the rear card sensor has detected a card.
However, the card has not past through the sensor. This could indicate a failed card sensor (always on). This may sometimes be caused by static on the cards.
To confirm this, switch to 'Hand Feed Mode' (on the front panel: Menu -> Hand Feed Mode -> ON). Cards are then fed (when requested) from the hand-feed slot on the front of the printer. If the error changes from Card Jam 06:05, to General Error 24:08, this would suggest a faulty rear card sensor (very rare).
Try leaving the printer switched off, and with the DC power disconnected for a few hours. If the problem persists, you should contact Magicard Technical Support.
With Best Regards,
MC.
Apr 09, 2012 | Magicard Rio Card Printer
Error code 24:03 magicard- card was stuck in machine
Hi There,
General Error 24:03;
This error is caused by a faulty RFID tag in the colour dye film.
Contact your Magicard dealer for a replacement dye film.
Sep 06, 2011 | Magicard Rio Card Printer
Really poor quality of the printed picture.
Have you cleaned the printer using a Magicard cleaning kit? Your printer neds to be cleaned using a cleaning kit every time you cahnge dye film to maintain a top quality print.
Cleaning kit contains 10 cards, 1 pen and 5 rollers - P/N M9005-761. You can buy it from your Magicard approved dealer or contact Magicard directly who will direct you to a dealer - info@magicard.com
www.magicard.com
Feb 15, 2010 | Magicard Rio Card Printer
Magicard Rio ID 2 Card Printer Logo
62 people viewed this question
Top Magicard Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
