Question about Panasonic PT-50LC13 50" Rear Projection HDTV
How to reset lamp timer of panasonic PT LC5013,lamp TY LA 1000
Lamp was changed,needs to reset lamp timer
SOURCE: projection lamp timer reset
I called 1800 211 PANA and they walked me through resetting lamp.
press recall and Volume- till solid screen shows, then hit recall till you see codes on top left, then hold volume- and mute(same time) till all codes return to 000000000000, then hit exit. turn off tv and check to see if it works
Posted on Feb 02, 2009
SOURCE: Need to reset the lamp timer / Panasonic PT-43LC14
hold the volume down on the TV and press and hold down the MUTE button on the remote control. Be sure to hold both buttons down at the same time and until the red light goes out.
This worked for me.
Posted on May 03, 2009
  • 380 Answers
SOURCE: Resetting the lamp timer for my Panasonic
You need the original remote to reset the lamp. Try to find a neighbor with a similar tv or buy one off ebay.
Posted on Mar 10, 2010
  • 50 Answers
SOURCE: lamp timer
hold the Volume Down button on the TV and the Mute button on the remote for 5 seconds.
asnowman
  • 788 Answers
SOURCE: My TV model is Panasonic: PT-52LCX15. I have a
Here is a link to replacing the lamp and the instructions for resetting the timer.
I hope that this helps you.
asnowman
http://911phone.net/Panasonic_TY-LA1000_Instruction_Manual%5B2%5D.pdf
Posted on Jun 21, 2010
How to reset the lamp meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
How to reset lamp timer panasonic pt-50dl54 ty-la2004
Consult the owner manual or call Panasonic customer service for the method for this model.
If I see one I do not know, I also will Google the model number with "reset lamp timer" etc. if the Panasonic line is busy.
Dec 19, 2012 | Panasonic PT-50DL54 50" Rear Projection...
Lamp flashes red and tv just shut off
You may have a bad lamp. Open the door on the side & pull lamp. The part number is TY-LA2006. They cost about $200-225. BE SURE to reset the lamp timer. If you buy an original Panasonic TY-LA2006 lamp, it will have instructions to reset lamp timer.
Jan 21, 2011 | Panasonic PT-56DLX76 Television
Have installed new lamp TY-LA 1ooo How is the new age timer set???
Press and hold Volume down button on tv front and Split/Play button on remote for 6 seconds to reset lamp timer.
TV will show you lamp timer reset confirmation display.
Sep 28, 2010 | Panasonic PT-43LC14 43" Rear Projection...
How to reset lamp timer on pt 50L C-13
Their manual says:
After lamp replacement, you must reset the lamp
time. Refer to the instructions enclosed with the
lamp unit (Part No.: TY-LA2005).
lamp unit (Part No.: TY-LA2005)."
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC13
Aug 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
