Question about Toshiba 43H71 43" Rear Projection Television
Service Menu Access?
Is there a service menu for the 43h71? If so how do you get into it?
  • Jason Houston May 18, 2007
    Thanks, I got in but not sure what I can do. Is there some type of guide that tells you what you can do?
    Trying to fix a RED out of convergence issue.
  • Jason Houston May 22, 2007
    actually yeah i replaced the ICs and still have same problem. the resistors look ok. i decided to trash the tv and get a new one.
    Problem Solver:
  • 7 Answers
I had a problem with my green gun having lines all over the place ,I cleaned the conections on the board on and below the gun.by pull the white conectors all out and spraying down with brake cleaner ,this morning thr the green is great and to night I,m doing the same with the re gun boards,i hope this will clean it up i will let you know.
Posted on Nov 22, 2007
    Scholar:
  • 77 Answers
Mute the tv then press mute again hold it down and press menu on the tv itself not the remote. Be carefull there is a lot of important stuff in there!
Posted on May 12, 2007
  • josh vannoy May 22, 2007
    1st go to the customer convergence menu and try to adjust red. Does it move at each of the points in both directions? If not (this is what i suspect you will see), forget about the service menu it will not move there either. Your problem is a circuit failure. Look around this web site and you will find a 1000 different posts about your problem. It will consist of a couple of amplifier IC's and maybe a few resistors. Then your adjustment should be minor and you can probably achieve it with the customer convergence. If the red moves fine in the customer menu then post again and i'll try to hel[p you through the service menu.
SOURCE:
Xerox 8860 stuck at Test Complete Initialize
The Hidden Service menu provides access to information pages and tests for diagnosing and correcting system malfunctions and accessing special features.
Access the Hidden Service menu as follows:
1. From the System Setup menu, go to Information --> Troubleshooting --> Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu
Reset the NVRAM:
Resets the system back to default settings and clears all network settings. If possible, print the Configuration page before resetting NVRAM.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 23, 2011 | Xerox Phaser 8500/DN Printer
How do I access RCA HDTV D52W23 Service Menu?
Shut unit off. Wait 10 to 15 seconds then press and hold volume down and channel down together for 10 to 15 seconds. This will get you into the service menu.
Apr 07, 2010 | RCA D52W23 52" HDTV CRT TV
Service Menu
You have to press >*<<*<* to access the service menu ...
Jun 20, 2009 | Sony Ericsson K550i Cellular Phone
How do I access service menu to reset lamp timer for Optoma H56?
In order to reset the bulb counter you need to access the Service Menu:
To access the Service Menu:
Turn on and warm up
press the following sequence:
Up
Up
Left
Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
Apr 15, 2009 | Optoma H56 Multimedia Projector
Toshiba Model #43H71
go to service mans menu and try horiz width adj..
Sep 22, 2008 | Toshiba 43H71 43" Rear Projection...
Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Apr 13, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Solid Fill pages Xerox 8550
I think this is the area you are refering to..
If not shoot me LOL..
Let me know ok.
The Hidden Service menu provides access to a large group of information pages and functions usable for diagnosing and correcting system malfunctions and accessing special features. Display the Hidden Service menu as follows:
  2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
Mar 21, 2008 | Xerox Phaser 8550DX Laser Printer
Hidden or Service menu
thank of you but i need access to menu service please help me
please mail key to access to menu service
thanks of you
Jan 07, 2008 | LG DU-42LZ30 42 in. LCD HDTV
Accessing the service menu
This is the right way, what is wrong with set?
Oct 06, 2007 | GE 31GT659 31" TV
Toshiba 43H71 43" Rear Projection Television Logo
91 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
