Question about Compaq Presario 722 (470029-690) PC Notebook
My compaq presario 722 notebook's keyboard's keys lost
I found the fixing of the keys poor.They easily becomes detached from the keyboard.My computer is still under guarantee period.
What can I do to fix this problem?
Some of my keys on my laptop are not working.
Replace the keyboard with a new one. Laptop keyboards are not that expensive.
Make sure that the replacement is compatible with your computer. To know more about it, please visit the website of your computer's manufacturer.
You can also try a USB keyboard to check if the non-working keys work with the other keyboard.
I hope this helps!
David
Mar 29, 2013 | Compaq Presario Cq57 Notebook Pc
How do I disable the wireless key on Compaq Presario CQ57 keyboard ?
We have several terminals with keyboards that are used by different people during the course of the day. We had a similar problem with the Caps Lock and Num Lock keys. Solution(s): Straighten out a paper clip and make a quarter inch hook at one end. Insert the hook under the offending key(s) and pop it up. You can easily replace the key should there ever be a need. No ham, no foul.
May 30, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Some keys are not working on my hp compaq laptop.that is the asdfzxcv keys. It is hard ware or software problem and how can i solve it...tanx
its either a bad connector, connection, or a bad keyboard, if you had a spill, then its the keyboard, a new keyboard will fix the problem.
May 21, 2010 | HP Compaq Presario v3000z Notebook
The keyboard is locked, is there an unlock code?
Try this
To lock keyboard with filterkeys activate sticky keys by pressing the shift key 5 times. Go to settings and click the radio button 'use filter keys' this locks the keyboard and gives nifty little sounds all except the taskbar button if keyboard has one. easily unlock by double clicking little clock emblem in the bottom right hand corner of screen and deselecting use filter keys. Make sure you hit 'apply'
Dec 04, 2009 | HP Compaq Presario CQ60Z Notebook
Loose keys
you can use a usb keyboard instead of the laptop keyboard until you find a replacement, there are fairly cheap
good luck
Nov 16, 2008 | HP Compaq Presario C500t Notebook
Keyboard
You can try to clean the keys with a cotton swab and alcohol. Just take the key off, carefully, the clean around the key and on the plungerwith the tip of the swab. Good luck.
Sep 28, 2008 | Compaq Presario Notebook
Compaq Presario 2500 (2598us) loose keyboard
You might want to check the keyboard connection. It sounds as if it's not connected or seated properly.
Aug 20, 2008 | Compaq Presario 2598Us Notebook
Laptop keys
On a presario the keys are hinged with a small metal hinge at the top that fits into two plastic clips and lets the key sit over the membrane of the keyboard. If the plastic clips have snapped it will involve the fitting of a new keyboard which isnt a user serviceable thing.
If it's out of warranty (HP now own Compaq, so it's them you'll need to talk to, but they will tell you the warranty status from the serial number of the machine) you might consider a rubber "roll up keyboard" along the lines of http://www.iwantoneofthose.com/bendi-light-up-keyboard/index.html - these are rubber folding keyboards that can be transported easily in your laptop bag but are still full size.
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
I have a Compaq laptop. The clip that holds the 9 key on is broken. Where can I get replacement keys and clips?
Probably need a new keyboard altogether.
Some here.
http://www.priorityelectronics.com/laptop-keyboards/presario-keyboards.htm
http://www.sparepartswarehouse.com/Compaq,Laptop,Keyboards.aspx
Refurbished ones here:
http://rogerhenson.com/parts.php?db=11
Mar 18, 2008 | HP Compaq Presario V2000 Notebook
Map keyboard on Compaq presario c500
Has everything changed, or just some of the keys?
Make sure the NUMLOCK is not engaged.
Jan 19, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 722 (470029-690) PC Notebook Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
