Question about York Yankees Bedding MLB Comforter
Failed electrical part
I have a number of AMANA P-tack heaters with electric heat strips.
There is...among other parts, a "can", plug in, made by YORK that controls the electrical operatioons of the P-Tack unit. I have a need for several of these "cans" and cannot find a supplier in the Seattle WA region whom can supply.
The part info is:
YORK SFS44155A14 / 15/5MFD / 440VAC / D6879847 / 50-60 HZ / S10000AFC 990423
This is information printed on the individual York part.
I need an outlet to purchase a number of these parts.
Please respond with information on "where" how I can obtain these parts . . ASAP
Respond to: L Alton @ CY Marriott Hotel . . . e-mail address: lalton@csmcorp.net phone: 206-478-1046
    Scholar:
  • 140 Answers
S10000AFC is just a capacitor. D6879847 CAPACITOR-ROUND (M11, M12, M16, M17) is a listing at Jonstone Jupply.
Posted on Jan 02, 2009
How to tell if your unit is a heat pump or just air conditioner with electric heat strip
PTH is a heat pump. PTC is an air conditioner only. I don't believe Amana makes electric heat strip-only models based on what I see in their literature. You can just do a google search and look for yourself.
Nov 29, 2011 | Amana PTH123B25AJ Heat Pump Air...
Amana #PTC153b50AJ ser 0410686783 Customer heard a pop in unit and it went off. Breaker was tripped. Reset breaker and unit runs in a/c mode but does not heat in heat mode. This is not a heat pump but...
I'm seeing a master switch on the control board, try a reset there. But, sounds like a bad element. You need to test continuity through your heater components. When testing a component unhook wires first, as they will still have continuity even if bad with wires attached.
Jun 04, 2017 | Amana PTC153B50AJ Electric Heat Air...
I have a vulcan wall heater with serial number 44674 made in 1981, needing to replace the fan as it's not blowing out hot air...Where can I find this part?
hello,
all Appliance part can be fine in various shop around you, our website www. appliancecanada. com is full of Electric heater Electric Cooktops · Gas Cooktops. Microwaves ... Sales centres are located in. Toronto and London, Canada. ... Scarborough, North York, Barrie, Vaughn, London, Woodbridge, Pickering, Whitby, Ottawa, Kingston, North York, Hamilton,e.t.c.
thank you and thanks for using fixya.
Jun 09, 2010 | Heating & Cooling
Electric Dryer Won't heat. Model Number LE8407W2. Do I replace the thermostat, the Thermal Fuse... both... any ideas? I have many part numbers, depending on what site I visit. Help!!! Bill
I would replace the whole heater assembly. From the model number given, you can get the whole heater assembly for under $42. That's the element, thermal fuse, and the limit thermostat. Here is the link to the part. This is the best place for appliance parts. This is the part number AP4072871
http://www.appliancepartspros.com/part_details.aspx?part_id=4072871
May 17, 2010 | Amana Dryers
Where is the fuse link located on a amana eletric dryer? my nephew hooked up the electrical plug wrong every thing els works now but the heat
it is right next to the heating element in the lower rear of the unit part# AP4048636, you will need to remove the heater duct on the rear to access it
Nov 14, 2009 | Amana ALE643RB Electric Dryer
Goodman heats but defrosts turns on before desired temp.
Yes. The defrost cycle of a heat pump is actually turning on your airconditioning to heat up the condenser to thaw it out. During this cycle your electric strip heaters "should" be adequate enough to compensate for the a/c being on. At about 30 - 34 degrees outdoor temp there is not enough heat in the air to to adequately heat your home with the heat pump only. Some technitions will use an outdoor thermostat to turn off the heat pump when it is under 34 degrees outside. If you are to cold when its under 34 degrees intall more electric strip heaters.. But if you do this your electric bill may go up significantly.
Welcome to the wonderful world of electric heat pumps (lol).
Good luck.
Mar 29, 2009 | Goodman GMS90703BXA Heater
Amana electric dryer will not heat/ LEA60AW Everything works fine but no heat...have cleaned all lint from inside the dryer by taking front panel off. What else should I check.... I noticed it wouild come...
Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most models). If you have 220v there the heater element is out. If you don't have 220v on the terminals of the heater the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow a kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
Feb 23, 2009 | Amana ALE643RB Electric Dryer
Electric heat
pull cover off unit to expose the coil fins. on right side there may be a switch that turns with a screw driver that switches between heat pump and elec. heat. we use this to stop the heater from dripping water in the winter, for some people
Feb 04, 2008 | Amana PTH123B35AJ Air Conditioner
Amana PTC153A50AD Electric Heater
1. copressure not working.
2 check spare parts of a/c.
3 wiring
Feb 02, 2008 | Amana PTC153B50AJ Electric Heat Air...
Amana ptec unit built into the wall
SOUNDS LIKE YOUR HEAT STRIP IS NOT COMING ON THERE COULD BE A NUMBER OF THINGS TO CAUSE THIS,BAD RELAY ON THE BOARD BAD HIGH HEAT LIMIT,BAD T-STAT
Nov 13, 2007 | Amana PTC074B25AE Electric Heat Air...
York Yankees Bedding MLB Comforter Logo
317 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
obsteiner
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
