Question about GE Monogram ZDP48L4GHSS Dual Fuel (Electric and Gas) Kitchen Range
GE Monogram Range Door won't go back on
We removed the door as simply as was stated in the manual but when we tried to put it back in it didn't line up. The right side clicked in but the left did not. We removed it and the hinge on the bottom left is not fully extended. Looks like the lock is re-engaged. Any suggestion on how to get the left hinge to extend while unattached? GE contract up Dec 23rd they won't renew Svc Contract until this matter is resolved so it's either call professional or find a solution. Thought I'd try you first.
  • lowney91 Jan 02, 2009
    We found the answer in the Installation manual: with a CAUTION:
    "If the hinge latch is not securely locked, the hinge may snap back and separate. If the hinge separates, you must apply pressure (possibly with your foot) to press it back together and then engage the hinge latch."
    We stood the door up on the floor and put a foot on the latch and pressed down opening it easily then snapped the latch lock into place. A simple foot & a little leverage - that's all it took.
    T
    Problem Solver:
  • 3 Answers
We found the answer in the installation manual not the owners manual. GE was not helpful.
Step on the latch while holding the door straight up (as if it were closed on the oven). Apply pressure with your foot to the latch and it will open fully. Put the lock in place towards to door. It was then easy to reinstall the door. The installation manual stated that the doors sometimes did this...
Frustrating that the installers are allowed to know this but the owners are supposed to remain in the dark -- unless they are clever like -- ah - ha - ME!
Service call averted!
Posted on Jan 11, 2009
  • Mary Moulder Mar 02, 2014
    YES! The hinge kept snapping back, because it was not extended out enough to allow the lock to hold it. Use your foot to extend, then lock, stick it in and almost voila! Thank you fixya and the internet!!!!!!!!!!
    What I am saying is, this totally worked!
My GE Monogram Frig door will not stay shut, it's lost its vacuum seal!
Check the fridge for out of level. Magnets on the weather-stripping hold the door closed. If there is something stuck on the seal, or too much weight in the door in an un-level fridge it will not make good contact. Try cleaning the rubber, and removing everything from the door after leveling. A good seal will stay closed even if the fridge is off.
Feb 23, 2015 | GE Monogram ZISS480DRSS Stainless Steel
Ge monogram bottom oven won't clean
Follow the owner manual instructions, some condition is not set or the door switch or door lack it not operationg. Could be the monitor switch on the oven latch.
Mar 02, 2013 | Ovens
Water dispenser not working
Then try replacing the dual water control valve. First look around the fresh food section door frame for the model number of your GE Monogram Here is a link to a service manual=> GE Monogram Serevice Manual PDF On page 15 of the service manual explains how to locate and change the water valve=> WR49X10043
I will be here should you have questions, Thanks Sea Breeze
Jan 25, 2013 | GE Monogram Side by Side Refrigerator
I have a whirlpool electric range model no. RF378LXKQ0. I removed the door and now I can't get it back on. I didn't relalize I was to put the pins in and I don't even see where they go.
**** the hinge to the broil position. Put a nail or something so the hinge won't pop back in the door when you go to put it back. Once ya have it back in the stove, remove the nail and close the door.
Sep 07, 2011 | Whirlpool RF378 Electric Kitchen Range
How do I remove a GE oven door, gas model number JGBP29WEJ1WW
With most gas ranges, you simply put the door in the "broil" position and lift the door from its moorings. To find the broil position, slowly open the door. You will feel a slight resistance when it is opened about 2-4 inches. This is the correct position for broiling foods, hence the name "broil position."
Nov 15, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Replacement of ice maker solenoid in door
Go behind the ice box and look for the water line going in. The water valve will be connected to the line. Be sure to shut off the water before attempting to do anythang.
Sep 05, 2009 | GE Monogram ZDI15C Automatic Icemaker
Red door spring GE monogram fridge side door
Spring closure part # WR2X8916 from Sears Parts.
Jun 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
GE Monogram Convection oven ZET837SB1SS
I would suspect a couple of wires are crossed.
GE puts mini-manuals in their units, which have wiring diagrams, schematics, etc. Very handy.
It will be folded up in a small envelope, usually behind the control panel or hidden elsewhere. That should help you.
Oct 26, 2007 | GE Monogram ZE2160SF Convection /...
GE Monogram ZDP48L4GHSS Dual Fuel (Electric and Gas) Kitchen Range Logo
257 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
