Question about Microwave Ovens
How do i replace the bulb in my matsui microwave model mat cjw211
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: replace the bulb in a sharp household microwave model R-4A97
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Jan 09, 2009
welcomejee
  • 10594 Answers
SOURCE: panasonic genius microwave light bulb
Does your microwave front display lite?
Posted on Aug 27, 2008
marked
  • 6487 Answers
Yes definitely that should be working fine again since it only stop working when the bulb blew,so go ahead and replace the bulb so you can use it again...
Hope that helps.......
SOURCE: Bulb Replacement in Microwave
You have to take off the case. Need a T20 Tamper Torx bit and a Phillips #2 Bit. There are 2 tamper-torx screws on the case to discourage inquisitive types / prevent untrained hands from entering. Once the screws are out (5 in total), slide the cover off the back. On the right-hand side, you will see the electrics. The bulb is behind the black oval shaped fitting that lies just behind the 2 big red wires that carry the high voltage to the microwave tube. Just pry over the bend-down metal tab, and lift off the black oval, bulb is attached to it. Replace, re-install, and test with case off and door open to ensure your replacement works. Re-install the slip-off case and screws. You're done.
Kermit
Posted on Jul 05, 2009
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
How to replace light bulb in combination oven model acm1580ab
Cannot find your model number, please provide make and model.
Jul 23, 2008 | Amana Microwave Ovens
I have to replace microwave light bulb. It's GE counter top Microwave JES1142PSE model. I hace opened the microwave and have located the bulb,but could not unscrew.I don't know needs to be pul
That exact model number is not showing up, so you may want to check the tag on or in the unit and look here for parts.
Most of the models in this class of ovens were not really made to be serviced, so GE only makes the turntable parts available.
It also sounds like your bulb is an assembly - the socket and bulb and one piece.
So your local appliance parts store should have a generic replacement for it. You should take the bulb.
Be careful when disconnecting the leads.
Apr 14, 2013 | GE Microwave Ovens
Can't figure out how to replace light bulb for model #721.66319
Sears Parts Direct lists the microwave, 72166319500 , as using the lamp, 6912W3B002L. This is available for $6.49 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Microwave-Parts/Model-72166319500/0582/0123245/50026833/00004?blt=06&prst=&shdMod= .
Unplug the microwave and wait a bit before starting to replace the bulb. To change the bulb, you first need to take off the entire cabinet (remove 4 screws on the back of the microwave and lift the part up). Then see the parts diagram on the page given above. There are 2 screws that hold the switch and bulb assembly to the frame of the microwave. I believe you should be able to pull the bulb housing down from the middle of the assembly and then push the unit up after replacing the old bulb with the new bulb. However, the bulb housing may have two screws holding it in place.
I hope this helps.
Nov 25, 2012 | Microwave Ovens
Hi where can i download the user guide for the matsui m299tcc microwave from please
http://www.manualsnguides.com/results_by_brand.php?ctexte=AEG
this should get you there .if you need more just type in matsui m299tcc mircowave on your search bar and lots of links come up,you can than pick the one best for you.
Good Luck
Apr 11, 2010 | Microwave Ovens
How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Jan 13, 2010 | GE JE1590 Convection / Microwave Oven
2nd hand matsui microwave with no instructions - model M175tc. how do i use the 'delay start'?
Contact DSG here.
Dec 05, 2009 | Microwave Ovens
How to set up matsui microwave oven.
If for some reason you don't have your owner's manual, I would suggest calling the dealer you purchased it from.
They may have a contact phone number for Matsui.
Nov 26, 2008 | Microwave Ovens
How to change the light bulb in a Matsui M155tc
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Nov 06, 2008 | Microwave Ovens
Panasonic genius microwave light bulb replacement The bulb on my Microwave model RMC275PD blew and no the microwave won't start, if I replace the bulb will the microwave work again? Thanks Richard
Aug 27, 2008 | Whirlpool RMC275PD Microwave Oven
Microwave Ovens Logo
258 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
