Question about Tower Aloha Breeze Fan
Manual for model FTT-8R tower fan
Have a tower fan and it made a noise and I found small spring and I have my fan apart Nd can't figure out where the spring came from and i need the manual or diagram on the indie Thank you Shar
I took apart my Eureka 71B hand held vacuum and a small spring fell out. I don't know where it goes and can't find a manual anywhere. Help?
Lonny,
I have a 71-B2 model myself and if you can take a picture of the spring, I can try to take mine apart and see if I can figure out where your spring goes and get back with you.
Aug 09, 2015 | Eureka 71B Easy Clean Hand Vacuum Yellow
Lasko tower
it will need the bearing changed. you can get copper bearings off ebay you just need to know the size or motor number.
Sep 28, 2013 | Lasko 2115 Wind Tower Fan
How to open the fujitronic ff606 digital tower fan
After taking out the 4 obvious screws in the back i had to take a small flathead around the sides of the casing (where the silver and dark grey meet, and there's a few notches on each side that you can pry on to get it to come apart. Might scratch up the casing a bit in the process so be careful on it.
Jan 20, 2010 | Fujitronic FF-606 Digital Tower Fan with...
FTT-R tower fan would oscillate but the fan would not run.
You might have a stripped gear in the tower where it oscillates. Hope this helps!
Jul 14, 2009 | Black & Decker BDTF1010B Tower Fan
Loud noises from Lasko fan motor?
The problem most likely lies within the fan motor of your Lasko unit. I just got fed up with my Lasko tower fan (model 2515) making a rumbling noise on and off and so I took apart the entire thing. I found the noise to be coming from the Decomin 2033014 motor in the unit. Took apart the motor and found that it is so cheap that it doesn't even have bearings! Just a few plastic discs on a spindle. I tried greasing the discs again but it didn't work. The only solution is to get a new motor. I am really disappointed in the quality of these Lasko fans.
Jul 07, 2009 | Lasko 2530 Elite WindTower Fan
Cleaning tower fan
The best way that I found to clean things like this is to find someone who has an air compressor and blow out the unit. But do this outside! The dust is usually unbearable. This is easier than losing small parts and can't hurt it at all!
Aug 17, 2008 | Sharper Image Deluxe Spire SI788SNX Tower...
Seville Classics MSC10166 Tower Fan
Possible Solution :
Taken From :
http://www.fixya.com/support/t193631-am_trying_fix_oscillating_tower_fan
"Most fan motors for fan over running have an internal overload. once it trips, it will not reset. it is a solid state device. it looks like a flat device or a small bullet device. if you've figured out how to take the fan apart, you could just remove the device and connect the two wires together and the fan will run. you won't have any protection on the motor however. the windings run warm, but if the bearings run dry the motor will slow down and the windings will get hot. this is the reason for the overlaod device - protection. its your call what you want to have."
Aug 14, 2008 | Seville Classics MSC10166 Tower Fan
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
I am trying to fix an Oscillating Tower Fan.
Sep 04, 2007 | Black & Decker BDTF1010B Tower Fan
Tower Aloha Breeze Fan Logo
80 people viewed this question
Top Tower Dryers Experts
Henry  Thomas
Henry Thomas
Jay Finke
Jay Finke
Are you a Tower Dryer Expert? Answer questions, earn points and help others
