Question about LG 42PG20 42 in. Plasma HDTV
LG42PG20D-AA firmware update
Have firmware 3.17 which has no options to unlock USB Service only. Need to update to at least 3.18 to get new menu options
2 Suggested Answers
SOURCE: I have the lg 42ld450
Hi my nameis Mike Houston of DISH Network and I see you are trying to play movies throughyour LG TV. I will send a link to help program the remote to the LG TV, http://www.dishnetwork.com/SupportSection/power-scan-instructions.If the DISH remote is programmed to the TV and you still can not get into theService Menu you will need to refer to the TV manufacture, I will send the linkto help with that, http://www.lg.com/us/support/index.jsp.
Posted on May 09, 2011
Where to find firmware upgrade for rca rtd317w?
IF the receiver had an internet connection, the receiver will find it's own firmware updates provided that you have it configured to automatically update. You might have to manually engage a firmware search via the settings menu - try the service or software tab.
IF not - then it will be much harder.Usually a call to the manufacturer of visiting their website is a good place to start to see if this is even an option for you.
Another way you can flash or update the firmware of electronics is by way of a flash drive into an usb service port on the chassis. YOu will need detailed instructions that you will need to follow to the "T" else you "brick" the unit.
If you have none of these then I will assume that firmware updates are not even possible.
May 30, 2014 | RCA RTD317 Theater System
Update firmware lcd tv toshiba 32pb10e
How to Update Toshiba TV Firmware
  1. Plug a USB flash drive in to an available USB port on your computer and copy any files from the drive that you want to keep into a separate folder on your computer.
  2. Format the drive as a FAT32 file system. This erases all of the files currently on the USB flash drive.
  3. Click here to open the Toshiba Support home page.
  4. Click "Product Support" in the menu along the top of the home page. The Product Support drop-down menu opens.
  5. Select "Televisions" beneath Choose Category.
  6. Select your type of Toshiba TV beneath Choose Family. For example, options include 3D TV, LCD TV and LED TV.
  7. Select your Toshiba TV model beneath Choose Model.
  8. Click the red "Go" button to the right of the Choose Model section after selecting your Toshiba TV model. The product support page for that specific TV model will be displayed.
  9. Select the "Downloads" tab. If there are no downloads available for your TV model, either your won't be able to click the tab or there will be a message within the tab that says there are no downloads at this time. If this is the case, no firmware updates are available for your Toshiba TV. Check back periodically, as firmware updates are released as needed and aren't scheduled.
  10. If there is content in the Downloads section, look in the Category section for an item titled TV Firmware. If this option doesn't appear, no firmware update is available. However, if this option does appear, click the clickable link associated with the firmware. The TV Firmware Update and Release Notes dialog box appears. In this dialog box you can see the size of the firmware update file, when it was released, exactly what it addresses and more.
  11. Click the red "Download Now" button and save the file to your connected USB flash drive.
  12. Extract the contents of the ZIP file on the USB flash drive.
  13. Disconnect the USB flash drive from the computer after the firmware update file saves successfully to the device.
  14. Power on the Toshiba TV and then connect the USB flash drive to the USB port on the Toshiba TV.
  15. Wait a few moments for the "Firmware file is detected in USB" dialog box to appear on the screen. Select "Yes" to update the firmware. A progress bar displays on the screen. Be careful not to turn your TV off while the firmware is updating. The progress bar changes to a "Success!" message after the update successfully installs.
  16. Disconnect the USB flash drive from the TV and then restart the TV. After the TV restarts you can resume using the TV as you normally would.
May 22, 2014 | Televison & Video
49.00FF service error hp color laserjet 4700n
This error is most often caused by out of date firmware on the printer.
Power off the printer and it restart and it should come to ready. If the error reoccurs, make sure that you have any print jobs in the queue of your computer cleared. If it still does not start without the error, unplug any network or usb cables and restart again. Once the printer is at at ready, use the control panel to go to the information menu and then print the configuration page. The firmware date code will be on the left hand side. Current firmware is 48.180.9.
If the firmware is out of date, see the link posted below to download the firmware update. Chose the easy firmware update as this is the most straight forward way to update the firmware. Once downloaded just double click the file you downloaded and it will run and ask you to chose the printer you want to update. Pick your 4700 from the drop down menu (should be fires option). Then update click update firmware.
You can find the current firmware here
Aug 09, 2011 | HP LaserJet 4700 Printer
On my PS3 when I try to update it, its keeps on saying error code 8002F994 and that the data is corrupted. Im tying to updated it to 3.5
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, may have crashed. You will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Before you replace the hard drive, try:
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Update using option 6.
PS3. Good luck..
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
The new avatar blu.ray dont work
If the firmware update still doesn't work, ensure you have a USB key connected to your player. I have the BDP-S350 and Avatar wouldn't work until I connected a USB drive to it. Ensure it is formatted correctly-anything new should work fine.
May 31, 2010 | Sony BDP-S300 Blu-Ray Disc Player
I Can Not Find a YAMADA DVD-7600XTV Region Unlocker
I don't know if this will work but I can atleast try to help
1) Open the disc tray.
2) While the tray is open, enter the following code with the remote's numeric pad: 2812
3) To change the region code, press the "Enter" button repeatedly. "Region 9" means all regions will be enabled.
4) Close the tray to save the desired setting.
Other Zoran Vaddis 776 based players have other options on this screen (such as Macrovision Enable/Disable) but this player only offers the region code setting (note the unused available space for other menu options).
If you press "Display" on the remote, the firmware version will be displayed.
or
1. Press "Eject"
2. Press "Setup"
3. Press 3x on the right "Präferenzen-Setup"
4. Press 7x Down "Land"
5. Press 1, 3, 7, 9
6. And 0 for code free
7. Press "Play"
Mar 29, 2009 | Yamada DVD-5520 DVD Player
No USB mode in Settings menu c250
Updating firmware video
http://www.youtube.com/watch?v=kVLoG4FWEjc
Jan 22, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Tony hawk project 8 wont load in psp
it might be that you need to update your firmware.
as newer games come out, they require features unlocked in the PSP.
the update of the PSP firmware usually lets you play newer software.
if the PSP loads the disk ok, goto the games XMB menu, and goto the option below UMB Disc.
It should say something like PSP™ Update ver. #.##
Jan 04, 2009 | Sony Tony Hawk:Project 8 ( Psp)
Problems connecting to the computer
You need to update your firmware first, then the settings menu will have the option to change the USB mode.
Get the firmware updater from here, under downloads on the right side of the page.
Dec 30, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e200 No USB Menu Option?
e200 or c200? I know that problem was fixed on the e200 with the latest firmware update. Download the sansa updater utility at the sandisk website and see if you can upgrade your firmware.
Jan 06, 2008 | SanDisk Sansa e200 MP3 Player
LG 42PG20 42 in. Plasma HDTV Logo
310 people viewed this question
Computer Repairing
Computer Repairing
