Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
White dots/specks on plasma tv screen
I just purchased panasonic 50" plasma tv. There are white specks that move horizontally across the screen.
  • Anonymous Jan 10, 2009
    I have same problem, also large "pixely" type squares near top of the screen.but mine is the 37" version and also I have had it for 5 years. Ive connected aerial/satelite etc to another and it works ok. I wonder if my panasonic is now nearing the end of its life??
  • 1039 Answers
SOURCE: I have a horizontal line going across the picture of my tv.
The panel is bad and will need to be replaced.
Posted on Dec 06, 2009
  • 16 Answers
SOURCE: 2 horizontal blue lines on samsung 50 plasma tv
Possibly could be the Y buffers --if the are next to each other could be a bad connection on a ribbon cable ---you need to call for service
Posted on Feb 06, 2010
dave1645
  • 834 Answers
SOURCE: White dotted lines across newly purchased Sansung 6300.
that is a connector error needs to be reseated but if it is new return it for an exchange
Posted on Apr 19, 2010
SOURCE: 50" Toshiba Plasma screen is flashing with flickering sound
www.tacp.toshiba.com/tacpassets-images/.../42hp66_om_e.pdf
http://www.fixdevice.com/smanuals/file/31149.html
Above, download these Service manuals, it will show you how to troubleshoot, and identify what board to repair change.
Posted on May 05, 2010
tvservice306
  • 458 Answers
SOURCE: 2 white horizontal lines have appeared across my
check su and sd board or replaced......
Posted on Jul 23, 2010
Blue & red horizontal lines in plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 18, 2016 | Panasonic Viera TC-P50G25 50" Plasma TV
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
I HAVE A PANASONIC 50" PLASMA TV IT HAS A HORIZONTAL 3 TO 4" WIDE LINE ACROSS THE SCREEN HOW DO I REPAIR IT MYSELF
sounds lie a couple bad drive Ics on the buffer boards. You can get replacement buffer boards and free technical assistance from www.tvrepairworld.com
Nov 28, 2012 | Panasonic TH-50PX50U 50 in. Plasma HDTV
Hello, why does my plasma tv have thousands of red and green flashing dots all over the dark parts of screen after it has been on for roughly half an hour? if i turn tv off for a while then turn back on...
I had a similar problem but mine was just red specks that showed up in dark scenes. I opened up my plasma and found the adjustment pots that are labeled Vsc, Vy. I then marked the factory default with a sharpie first. Then I lowered the Vy a little and my red specks disappeared. Now my tv looks awsome again like it was new.
May 10, 2010 | Samsung DLP HL-P5663W 56" TV
Apr 19, 2010 | Samsung SP-P4251 42 in. Plasma EDTV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
My 50" Plasma has developed a band across the middle of the TV
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If you don't have the reciept then call 1-800-SAMSUNG.
Jan 24, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung 50 in dlp
It sounds like the Screen is coming to the end of its life. Has the screen been recently moved or dropped? Plasmas tend to lose its contrast after 60,000 hours of use. It could also be a loose connection from your source to your TV. Have you checked all your connections to the TV?
Oct 19, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
White speckly 'snow' on screen
y sustain board needs adjusting or replacing
Oct 10, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
320 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
