Question about Canon PIXMA iP8500 InkJet Photo Printer
I need ot manually align my printer head and i don't know how
  • 435 Answers
Please click the below mentioned link to download a word document containing the steps to align printer manually:
Align Print Head manually
Thank you
Posted on Feb 07, 2009
How do I align print head Epson sx115
Hi there
The easiest way is from the Maintenance tab of the monitoring software that comes with the printer. I don't know of any way to align heads from the buttons.
If you right click on the printer icon on the task bar, then a menu will come up and you can then click on the "Head alignment " and work from there. Alternatively bring up the "Devices and Printers" in Control Panel and under Printer Management click on "Adjust print options and then the maintenance tab on the window that comes up.
If you need more information, you can a user manual as a zip file and then HTML format here:
Epson Stylus SX115
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 16, 2015 | Epson Office Equipment & Supplies
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
The printer wont let me do anything because it says I have an alignment problem and to take the tape off of ink cartridge but there is no tape! Its not a new cartridge I don't know what its talking...
May be dry the ink or refill ink cartridge so , it could't properly ink out the nozzle. If possible u can batter manually clean the print head. Then try to it. Otherwise need to change the ink cartridge.
Jun 13, 2013 | Office Equipment & Supplies
Will not proceed with reallignment--says to insert paper and press ok but then it doesn't do it.
This device having auto alignment Technic,If print heads are clogged it will not print align page properly result alignment will not completed. In this condition it will ask for align print heads when ever printer switched on. To over come from this situation clean print heads fist, manually or though tool box, then try for align. If printer heads are out of health condition replace faulty print heads then perform align process.
Oct 27, 2011 | HP Photosmart 3210 Printer
Head Alignment error on the display, cant find my manual, How do I fix this.
If you don't know were to find the manual..try to search it in google, just type the model and the name of the product.
Sep 17, 2011 | Canon Office Equipment & Supplies
Alignment Issue
Browse through the menu, there must be a head alignment test/function. Also inspect the printer driver and/or utilities installed on your computer and find a head alignment function.
It's not complicated, either it's fully automatic, or you'll have to look at a printout and choose the best-aligned lines, depending on printer model.
Nov 01, 2009 | Lexmark X7350 All-In-One InkJet Printer
Prints every other line
Use the cleaning cycle first.If it completes do a nozzle check and then to align follow below.
You need to hook it up to computer to do a manual head align through the printer properties maintenance section.
Jun 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I keep getting this message when I try to align the print head. An error occurred during automatic print head alignment. Press the printer's RESUME button to clear the error. Refer to the user's guide to...
The print head is the carriage that holds the ink cartridges and has tiny nozzles on the bottom that spray the ink on your paper. The nozzles have to be aimed (aligned) either automatically, or in WinXP with the following manual process:
1 Left click on the start button
2 Open "Printers and faxes" on the Start menu.
3 Find your printer on the printer list and right click on it once.
4 Select "Properties" from the pop-up menu.
5 Click on the "Maintenance" tab at the top of the new window.
A selection page for all sorts of upkeep items is then shown. Manual alignment of the print head is one of the choices.
Jan 23, 2009 | Canon i860 InkJet Photo Printer
After printing he print headaliengment
Greetings!
I dont know the kind ot printer that you have, but that happen when the printer was set to that setting. Just open the printer icon/setting then properties find the setting and removed that kind of action.
Thanks
Nov 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Canon PIXMA iP8500 InkJet Photo Printer Logo
335 people viewed this question
old marine
old marine
