Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Installed new EOC for Sears Kenmore Elite 790 46609500 oven.
My Sears Kenmore Elite oven fried out on Thanksgiving Day. The Sears technician told us we needed an EOC. We weighed our options--new stove or EOC--bought the EOC and installed it with the power off. We swapped out the wires from the old EOC to the new EOC. After we put the power back on we still have the same problem. The burners work, the oven doesn't. Still flashed F30. Is there a reset button? Some other fix? Please help. This model is 790.46609500.
  • Anonymous Mar 13, 2014
    installation of new eoc board
  • 15,935 Answers
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
My gas stove beeps and displays F3 what is is a kenmore 970-568212
This range was made by Frigidaire for Kenmore. Thus the F3 error could mean a problem with the temperature sensor, the EOC (electronic oven control) or the wiring between the two. You'll need to get to the back of the range and check the resistance at the sensor. In a ~70 degree F environment, the sensor should have a resistance of ~1100 Ohms. (The sensor is connected to the EOC by a pair of violet wires.) Make sure to rule out a problem with the wires, if the resistance tests out of specifications.
If the sensor gives the correct resistance and the wires are fine, replace the EOC. Please check that you have given the full model number, I can't find this model anywhere at Sears Parts Direct or elsewhere.
If the stove is under warranty, contact Sears for repairs. I hope this helps.
Aug 29, 2015 | Kenmore Sears Stove Grate Replacement Gas...
F14 Error
First please get the full model number of the range. Kenmore products are made by other manufacturers and the error codes will depend on the manufacturer.
Most likely, you have a Frigidaire range (for example a 970. model). Then the F14 code could indicate a problem with the P12 ribbon cable connector tail, a bad EOC (control unit), or touchpad. First try disconnecting and reconnecting that cable. Next the EOC should be replaced. Finally the touchpad should be replaced.
If this is a brand new range, contact Sears to get a repair person to fix the range. If you bought it used, see the above possible solutions.
I hope this helps.
Dec 24, 2013 | Kenmore 30" Electric Double Oven...
F 10 code when I try using oven
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It will be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Please rate and have a great day:)
May 18, 2009 | Kenmore Ovens
Electric Oven will not turn off
It's the EOC. However, I replaced my EOC on my Kenmore electric range and it still does not work. I had a Sears tech come out and check the stove. The temp probe was fine and he told me it was the EOC. After I told him it was already replaced, he said, "there's nothing more to do." I'm currently looking for a new stove.
Sorry, but try to replace your EOC and check the temp probe for resistance.
Apr 05, 2009 | Kenmore 96112 / 96114 / 96119 Electric...
Kenmore Elite SS Bottom draw freezer refrigator is a lemon
Hi!!! you have to change your freezer fan and bi-metal which are upgraded good manufacture and see if you have a service flash and covered under warranty..good luckk...
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Washing machine
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and it costs $800 to replace the unit with the bearings. They will not do anything about it except try to sell you a new washer.
I will not buy this washer again (especially from Sears).
Jan 14, 2008 | Kenmore Elite 45986 Front Load Washer
Clanking noise during spin cycle
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore washing machine shakes when spinning out
our's did this, it shook horribly. it turns out one (or more) of the shocks had come out and the technician had to come out and replace the shocks.
Nov 03, 2007 | Kenmore Elite 45986 Front Load Washer
Spin cycle problem
Which machine exactly do you have ?
Aug 31, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
1,664 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
