Question about Blue Flame Charmglow 30K BTU NG Vent Free Space Heater
The digital thermostat control will not work.
I have a Charmglow model # cgl300ehbc. About a month after I bought this, it stopped sensing the room temp and the digital thermostat control will no longer work. I'm guessing the room temp sensor has failed, but how/where can I get a new one?
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Compressorruns fora short time
the thermostat controlling your unit likely has a window type of programming for digital or mechanical adjustment for older style thermostat that sets a minimum off temp and a maximum on temp, there may be an adjustment to set the range it operates at, otherwise you may have a defective thermostat controller unit and it needs replacing also insure that the temperature sensing element is clean and free of dust build-up and your filter is clean
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
Stopped working.Lights working.Di last year
Without the age and model number makes it a problem diagnosing. However, it is not unheard of for a cold control (thermostat) to shut off the machine and hang up and refuse to return to the on position. The cold control on temp is usually about 37 degrees. If left off for 8 hours, the sensing bulb on the thermostat would reach room temperature, and with that additional temperature (heat) could cause enough pressure on a balky thermostat to reset to the on position.
Oct 30, 2009 | GE Refrigerators
Broken thermostat for the Charmglow HBL-15SDLP/M20
you can get your parts at this web site.................www.grillstuff.com......scroll down to CHARMGLOW parts..enter your model # ...they will ship the part to you...I was just at that web site to verify.....GOOD LUCK..!!!
May 09, 2009 | Heating & Cooling
Blue Flame Charmglow 30K BTU NG Vent Free  Space Heater Logo
Top Blue Flame Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Blue Flame Pool and Spa Expert? Answer questions, earn points and help others
