Question about Texas Instruments Office Equipment & Supplies
How do you clean the print head on TI 5040 ii
2 Suggested Answers
SOURCE: cleaning the print head
I just 'adoped' my parents old TI5040 this weekend (5/31/08) and need to do the same. However, I cannot figure out how to even open the case to GET to the print head.
Posted on Jun 02, 2008
How do you change the ink roller in a TI 5005 ii
Replacing the Ink Roller
  1. Press the OFF button.
  2. Remove the printer compartment cover.
  3. Remove the ink roller from the right side of the compartment. Insert your index finger, nail down, under the tab on top of the ink roller. Gently lift the ink roller out of the compartment.
  4. Lower the new ink roller (IR-21) into the compartment and align the hole in the ink roller with the pin in the compartment. Press down until it snaps into place.
  5. Replace the compartment cover.
Warning Never refill or moisten the old ink roller. This can damage the
printing mechanism and void the warranty.
The full manual can be found here:
http://www.retrevo.com/support/TI-TI-5006-II-Calculators-manual/id/426ci758/t/2/
Nov 18, 2013 | Texas Instruments Office Equipment &...
How to clean the print head
No easy way to clean the print head. You will need to remove it from the printer to gain access to the area to clean. What does the label look like on the disc? Streaks is probably a dirty print head. If sections of the label are missing it could be the print head or heat roller. Look at the re-transfer (clear) ribbon. If the missing part of the label is left on the ribbon you have a heat roller issue.
Mar 12, 2013 | Rimage Everest II Printer
How I load the paper roll in my TI-5045 II A printing calculator? Dr. H. Laaly Tel 310-559-6080 Laaly.Roofsandroofing@Gmail.com
Follow the (somewhat) illustrated instructions in the guidebook available on the manufacturer's web site at
http://education.ti.com/downloads/guidebooks/printer/5045svc/5045svc.pdf
Jul 20, 2010 | Texas Instruments TI-5045 SVC Calculator
KNOCKING SOUND AT WARM-UP AND DURING PRINTING. DIRTY SMUDGES ON PAPER. I CLEANED ROLLERS I COULD FIND, BUT PROBLEM PERSISTS
sounds like you may have a flat spot on fuser pressure roller causing a knocking sound as it warms up and when it prints. You may need new fuser assembly...
Dec 29, 2009 | Brother HL 5040 Laser Printer
Have an iP90, but the color ink won't print.
When Printing Becomes Faint or Color are Incorrect, the Print Head Nozzles are probably clogged.
Follow the procedure below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
Print the Nozzle Check pattern to determine whether the ink ejects properly from the Print Head Nozzles.
a) Using RESUME/CANCEL button.
I) Ensure that the printer is turned on, and then load a sheet of Letter Paper.
ii) Hold down the RESUME/CANCEL button until the POWER lamp flashes twice, and then release it immediately.
b) Windows
i) With the printer on, load a sheet of Letter-sized plain paper in the printer.
ii) Open the Printer Properties.
iii) Print the Nozzle Check Pattern.
Click the Maintenance Option from the Menu.Then click Nozzle Check from the pop-up menu. Then click Print Check Pattern.
iv) When the confirmation message is displayed, click OK.
v) Confirm the nozzle check pattern.
Examine the Print Nozzle.
Step 2 : Cleaning the Print Head.
a) Cleaning the Print head using RESUME/CANCEL button.
i) Ensure that the printer is on.
ii) Hold down the RESUME/CANCEL button until the POWER lamop flashes once, and then release it.
b) If you pressed the Cleaning button on the Examining the Nozzle.
Check Pattern screen displayed after the nozzle check patter was printed, start the Print Head cleaning procedure.
i) Ensure tha that the printer is on.
ii) Open the Printer Properties dialog box.
3) Start Print Head Cleaning,
- Click the Maintenance tab.
- Click Cleaning.
- Select the Print Head to be cleaned, and then click Execute.
Print Head cleaning starts when the POWER lamp starts blinking,
Important : Do not start any other operations until the Print Head Cleaning finishes. This takes about 60 seconds.
4) Check the Print Head condition.
i) Click the Print Check Pattern in the nozzle Check dialog appeared after cleaning are done. When the confirmation message is displayed, click OK. A nozzle pattern will be printed. Do not perform any operation until printing is completed.
ii) Observe the printed nozzle check pattern to check the Print Head condition.
iii) If the problem persists after you perforned Print Head normal cleaning 3 times, execute Print Head deep cleaning.
Step 4 : Print Head Deep Cleaning.
If print quality does not improve by standard Print Head cleaning, try Print Head deep cleaning, which is a more powerful process and comsumes more ink.
1) Ensure that the printer is turned on.
2) Open the Printer properties dialog box.
3) Start Print Head Deep Cleaning.
i) Click the Maintenance tab.
ii) Click Deep Cleaning.
iii) Select the Print Head to be cleaned, and then click Execute.
iv) When confirmation message is displayed, click OK. Print Head deep cleaning starts when the POWER lamp starts blinking,
Important : Do not perform any other operations until the Print Head deep cleaning is completed ( about 2-3 minutes).
i) Print a nozzle check pattern to check the Print Head condition.
ii) If the problem persists, perform step 3 again.
iii) If the problem persists, the printer may have run out of ink.
Replace the ink tank.
iv) If the problem persists, the Printer Head may be damaged. Contact your dealer or Canon Customer Care Center.
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA iP90 Mobile Printer
How to clear paper jam in HL 5040 laser printer
Clearing paper jam in a printer is simple almost seven step procedure.
i. Put off the printer.
ii. Open all the covers/shutters on the printer (usually one in front or top and one at the back.
iii. Now pull out the cartridge carefully.
iv. Site the paper that has jammed and pull it out in the opposite direction of its movement. (Pulling the paper in the opposite direction is important for the printer mechanism).
v. Return the cartridge and press it firmly inside.
vi. Close all covers.
Power on your printer and you should be able to print again.
Dec 04, 2009 | Brother HL 5040 Laser Printer
I have a TI-5045 II Calculator that wont print
I have the exact same problem (just happended recently) with my TI-5045 II after 25 years of good service. My solution? I just bought another model: Sharp EL-1801V at Stapels for about $31.00. To get the old one fixed will probably cost me $25.00-30.00 just to diagnose, plus shipping and parts and labor. And that assumes I can find a shop to do it, or that TI still stocks the part(s) gone bad. Same old problem with all technology.
Sep 16, 2009 | Texas Instruments Office Equipment &...
Cleaning the print head
May 05, 2008 | Office Equipment & Supplies
55 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
