Question about Samsung DLP HL-P5663W 56" TV
Samsung memo correctly shut the light door - Samsung DLP HL-P5663W 56" TV
    Top Expert:
  • Samsung Master
  • 14,553 Answers
These sets where the door is to gain access to the lamp there is a lever--it is a safety switch that may either not be engaged or bad--it can be checked for good bad with a resistance check and sometimes the switch gets moved enough for it to shift out of position--if rear door then tape it in the closed position to see if not engaged by the door.
Called a lamp door.
Posted on Oct 24, 2012
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
How do set the time and date on machine
Press and hold CLOCK until the message window displays C, and the default day is announced.
To change the day setting, press MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
Press CLOCK. The current hour setting is announced. The correct day setting is saved.
To change the hour setting, press MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
To change the minute setting, press MEMO/REPEAT or ANNC/SKIP until the correct minute is announced.
Press CLOCK. The current year setting is announced. The correct minute setting is saved.
To change the year setting, press MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
Press CLOCK. The new day, time and year are saved. The correct year setting is saved.
To check the clock, press CLOCK.
The above is from page 5 of the manual at
http://att.vtp-media.com/ecp/documents/product_Product/223/UserManual/944/1739_manual.pt2_i6.pdf
Jun 21, 2011 | AT&T ATT1739 Digital Answering Machine
Water is coming out of the freezer part, just from under the section the eyes and water are dispensed, the temperature light keeps flashing on and of at -22 degrees and everything inside is melting. What...
  1. Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
  2. Step 2 Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets
  3. Step 3 If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls.
Apr 10, 2010 | Samsung RS2556 Side by Side Refrigerator
The TV shuts off by itself.
Verify you are installing the lamp door correctly. Some units require a swinging motion for installation. Insert bottom, swing top of lamp door into place. Or, you may just need a new lamp.
Mar 15, 2010 | Samsung HLP6163W 61" Rear Projection...
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
2002 jeep cherokee limited
Probably a bad door switch or a malfunctioning body control module. If it's an analog problem it could be the door switch (usually driver's side) or a broken wire in the harness going into the door as the constant movement of the harness when opening and closing the door eventually affects the wiring.
Jun 06, 2008 | 2002 Jeep Grand Cherokee
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Samsung DLP HL-P5663W 56" TV Logo
Jerry Greenberg
Jerry Greenberg
