Question about iLO 3200 32 in. LCD Television
MY ILO TECHNOLOGIES FLAT PANEL DISPLAY MODEL NO L15FCBT WON'T POWER ON AND I AM NOT SURE HOW TO TAKE OFF THE BACK PANEL TO LOOK INSIDE I NEED HELP WITH BOTH PROBLEMS
3 Suggested Answers
  • 3 Answers
SOURCE: lcd tv black but green power light on
If you're using a cable box , connect box to tv using component cable .
Posted on Jan 08, 2008
  • 586 Answers
SOURCE: ilo flat panel tv model
The reason your television is not powering on is simply because the storm has damaged a component in the unit of the television. The most likely component that might have been damaged is one or more of the components on the power panel.
The solution is for you to disassemble the television and assess the power supply board, you will find the bad capacitors, then replace them and the television will be in good condition once again. But be sure to have checked the main power socket to know if it is not damaged yet before proceeding with the capacitor replacement.
hope this helped.
Elect_Comp
Posted on Jun 22, 2011
ILO TV won't turn on
You will need to have the set professionally diagnosed. You could either have a faulty power supply or main board. You could also try unplugging the set for a bit and plugging it back in. I doubt it will solve your problem but it is worth a try.
Sep 03, 2012 | iLO Televison & Video
Norcent Technologies LM173SB 17 in. Flat Panel LCD Monitor Won't work with Windows 7
I ran into this very problem myself, the issue is that the monitor only supports 1280x1024 resolution MAX. Windows 7 cannot detect this monitor and so it does not know it is limited to this resolution, so Windows 7 is putting out a higher resolution at startup, thus the monitor tries to autodect for a second but then just goes blank because it doesn't understand (and can't display) the signal. The only solution is to use another monitor and adjust the resolution to 1280x1024 or lower, but I run into a problem where as soon as you remove the other monitor and restart, WIndows tries to "plug & play" the monitor all over again at startup. So you're best bet really is a newer monitor unfortunately, I only use my old Norcent monitor with my XP computer.
Aug 29, 2012 | Norcent Technologies LM173SB 17 in. Flat...
My 32 in. ilo sdtv won't stop with the
Download the user manual to your ilo TV. For it with its exact model number. Refer the manual for details.
Jun 07, 2012 | Televison & Video
Power in house went out. T.V. wont turn on.
Did you have a surge protector on the TV? Have you tried unplugging it for 5 minutes, if not try that. If it still won't work contact your local electrical power provider and start a claim for damages from the power outage.
Jan 24, 2012 | iLO Televison & Video
Power won't come on
No power signal lights appear?If no power lights try to check the fuse inside your TV.remove the back cover to see the fuse location.It is located besides the power supply.check it if busted,then replace the same value of fuse.Unplug first before removing the cover to avoid electric shock.thanks!!
Jul 07, 2011 | iLO LCT32HA36 Television
No picture is coming on screen.
Have you checked your power outlet and are you sure every thing is plugged in correctly for one for two are there any other signs that may help us help you does the power light come on or no. Have you tried a different outlet.And we will need a model number and a manufacturer RCA,ILO,Visio ect. Model number is on the back of the TV and will tell you the size.
Apr 24, 2010 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Need a ilo l15fcbt part #s1p1w1 pwb-0785-01
This particular monitor looks like is not longer available....
Did anyone have the driver for this same lcd display??
please contact me by email..
Thanks
D.C. Salazar
Mar 22, 2008 | Computers & Internet
Ilo 42 inch plasma display tv
tot2523, your on off switch needs to be replaced. We have one, and we are now on our 2nd repair of the switch. First one blew and now the power switch won't go on. It seems it is a flaw with this t.v. Our t.v. is only 2 years old.....
Jan 14, 2008 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Lcd tv black but green power light on
Jan 04, 2008 | iLO 3200 32 in. LCD Television
Cannot change channels
Hi! I have been through this situation on a 26" model of ILO LCD TV. I think the problem you have is the same, but could you clarify one thing for me? Is your model an ILO-3200, or is it an ILO-32HD? I suspect 32HD, because I know the problem exists on the 26HD models which are basically very similar in design and say manufactured by Initial Technologies on the back of the set. Does your unit list this manufacturer on the back? Let me know. Thanks!
Sep 30, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
54 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
