Hi. I have a Master Vision Son1 remote control but have lost the manual and dont know how to use the master remote.
4 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Strand 3 in 1 Master Remote Control
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: Strand Master 3 in 1 Remote Control
yes my master remote have been fix my tv is wor king now if you want to fix it type in google comcast master remote 3 in 1 and you can see lots of result but one of them are the right result click on comcast 3 in 1 universal remote i know this will help you but read the instruction very very very carefully.
Posted on Dec 30, 2008
SOURCE: Master Remote Control codes
I have a strand 3 in 1 you just need to press and hold shift/setup until the light stays on. Then press channel up. DO NOT press the on/off button but just let it cycle until the tv turns off. THEN press the ok button immediately.
Posted on Apr 12, 2010
Puk code nokia 2690
- To unlock your Nokia 2690 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone.
- With the help ofthisIMEI code we can get the master code of your mobile and unlock the mobile and resetitwith a new password.
- The IMEI number can usually be found on the sticker underneath the battery or
bytyping*#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Oct 08, 2011 | Televison & Video
I have bought 2 new remotes for my centurion gate motor and the shop assistant told me how to program them.....except it doesn't work - please can someone give me step by step instructions on how to do...
On a D5 Motor To program the first remote place the jumper on in learn mode over J2 and Central Pin after it has completed flashing remove the jumper. Press the button on the remote you want to program, wait until the gate starts moving. To program addtional remotes use the master remote. First remove the jumper so that the 3 pins are exposed. Press the button on the master remote and hold it in. Notice that the LED next to the pins starts flashing after it has flashed 11 times release the button. Now press the button on the second remote and hold it in it should learn the signal.
Jan 13, 2011 | Televison & Video
How to unlock parental control ? I dont have the original remote and I dont know the password also. Only few channels are locked.
From the user manual p65.
Lost password ? In the password screen (see page 54), enter the following master password: 4357. The master password clears your previous password; it cannot be used to temporarily unblock channels.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
No instruction manual or codes for strand master remote 3 in 1
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Oct 01, 2009 | Universal Remote Control Remote Control
Need remote codes for panasonic tv for remote master 580
hi guys
i havea big master blaster that needs a remote control? it's a xbs rx-ds 45
Mar 29, 2009 | Televison & Video
I have looked about the place for anything to o with strand master, and found nothing. Can you check the model of the remote for me.
thanks
regards
Graeme
Apr 01, 2008 | Televison & Video
Iiama vision master pro 511 MA201D - horizontal distortion adiustment
FACTORY MODE:
Turn ON and OFF the Power Switch while pressing the MENU Button. Turn ON the Power Switch again while
pressing the – Button and you are in the Factory Mode. The following menu appears on the screen when you
press the MENU Button. Turn OFF the Power Switch to exit
Dec 14, 2007 | iiyama Vision Master Pro 510 22" CRT...
SONIX tv remotve code for sky
I bought this sonix Lcd Television without remote.I bought a master remote but i dont know the code to use on the master remote.please
Sep 09, 2007 | RCA RCU1010RF LCD Touchscreen Remote...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
