I changed both Convergence Ics and no only can hear the tv come on and no lights or anything. What could be wrong
TV was shrinking and picture was bowing. Changed convergence Ics and checked the resistors. Resistors are ok. What could be Wrong now?
  • SD Tech
    SD Tech Oct 26, 2012
    Trying to change the glyol is dangerous and risky--blue will usually be bad but my guess now is a careful inspection is going to show glycol has leaked from the seals somewhere and got on the boards--careful as very toxic---look for the leak I suspect you will find--water will remove it but gloves should be used as it will get absorbed into your body if touch it. got glycol leak?
  • SD Tech
    SD Tech Oct 27, 2012
    a simple way on this brand is to unsolder all 18 pins on both chips completely and see if set comes on at all--the knock off thing is a myth. Upper right corner on the chips is a letter and number sequence---production code--seen Mitsubishi chips that wholesale for 22. 00 with same production run number as the generic that cost 7.00---like looking on ebay and seeing exact same auto part with a wide choice of prices.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
TO EVEN TRY TO HELP NEED BRAND AND MOST IMPORTANT MODEL NUMBER.
Posted on Oct 24, 2012
  • Lead Oct 25, 2012
    Sorry, I have a Phillips Magnavox 9P5534C103. The pic was bowed and shrinking. So to start with we thought while we were working on the TV we would go ahead and chang the Coolant Fluid because it was discolored. And clean the lens. That task went pretty good. Then all that worked good and Tv color was better but pic was still bowed and shrinking. On the convergence to line up color the green is very blured. So he changed the Convergence Ics. Then when we went to cut the TV back on and you could hear it try to come on but nothing nothing but the light on the front of the TV. And I cant find a service/repair manual. Anyone have any suggestions.
  • Lead Oct 26, 2012
    He checked all of the resistors and they all seemed. We are going to check it out again this weekend. Checking the fuses and etc. It's been a busy week. And I think the ics i bought ended up being the knock offs i am reading about. How do we check to see if i got bad ics. We are looking for a service/repair manual for it? Thanks for all of the info we have got this far.
2 Suggested Answers
techman
  • 3130 Answers
SOURCE: convergence no adjustment
There are black in color circuit protectors in the set that have blown because of the bad convergence IC's. You will need to measure the voltages on the ICs and make sure you have the correct plus and minus voltages. There should be about + and - 24 volts on each IC. I'm afraid the only way you will know what voltage are what and where they should be would be to get a service manual. i am sorry i do not have this model to share with you. Good Luck.
Posted on Apr 27, 2007
The color has changed so that grass looks like burned out fields and flesh tones look sickly. the menu color options do not seem to do anything, and blues still look fine. help! Baseball games look...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems
Jun 25, 2011 | Televison & Video
Focus Error I am getting double picture and the colors are off. When trying to auto focus the blue lines are wavy.
Replace Convergence ICs ,Big black ICs will have PN# on them example STK 392-110
Mats has ICs 1-800-628-1118
Jun 05, 2011 | Toshiba 42H82 42" Rear Projection...
The top and bottom of the picture makes a rainbow effect toward each other in the center of the screen++++++++TV. model 3 ws55807 it's a 55 inch screen the problem occurs all the time. I have no TV repair...
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than this tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.Fix the tv convergence board to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Mitsubishi WS-65807 65" Rear Projection...
There is no picture when TV is turned on and all you hear is a faint chirping sound. Sounds like something is trying to restart. There was an issue with our cable, once it came back on later in the day the...
The problems ur tv having is also parts of the tv Convergence board are dead,but it is totally dead to causes this problems,if convergence board it still have some functions left.Tv will only have colors R,G,B will mis alignments,have colors shadows pictures and 3D pictures look alike,but convergence board are not getting any voltages at all that why u just hearing faint chirping noises that it.The tv convergence board,must require to changes 2 STK convergence ICS and some or all of it resistors too.For the covergence board have fully functions again to solved this problems.The shop will cost u like $300-350 for parts and labors.
Jan 31, 2011 | Philips 60PP9202 60" Rear Projection...
My sony kp57ws510 model tv has double vision and the double vision that shouldnt be there is in blue and red..whats wrong with my tv?
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors on the tv convergence board are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 29, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
The picture on my phillips rear projection tv is red and I can't change it by adjusting colors. What is wrong and how can I fix it?
Tv have colors lines R,G,B mis alignment any colors,shadows colors, 3D pictures,the tv have a problems known as a convergence problems.The tv convergence board is dead.The 2 STK Convergence ICS and some or all it resistors are dead too.Must replaced these parts to solved convergence problems.The shop will cost $300-350 for parts and labors.
Aug 05, 2010 | Philips Magnavox 51MP392H Rear Projection...
EVERYTHING IN WRITING IS DOUBLE AND THE PICTURE IS DISTORTED
Hello Tim this is a very common problem with the projection tv set, the problem is coming from the convergence board with faulty ICs that have to replaced in order for your tv set picture to work properly,they do sell convergence repair kits for your tv set but i would not recommend this the reason being is that if you make a mistake while changing out a component your whole tv set is gone not going to work anymore so for this i would recommend for you to call a near by tv repair shop and have a tech come out and change this ICs for you, after you change this ICs from the convergence board your tv set should go back to working normal on the link below you can check out how a convergence board looks like thank you hope this helps.
http://bestbuy.partsearch.com/content/pages/tv-convergence-boards.html
Aug 29, 2009 | Sony KP-46WT500 46" Rear Projection...
Bad convergence, now wont turn on at all.
The convergence ICs have failed and thats what is shutting the set down. You will need to replace both convergence ICs they are STK394-250 you can get replacement ICs at the following link with free shipping and free instalation instructions with pictures s you can do the repair yourself. Here is the link.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Mitsubishi WS-55311 55" Rear Projection...
Old Projection telvision on the fritz
you need to change the CONVERGENCE ICs , if you cant do it then it needs to be serviced by a HITACHI authorize service shop , hope this helps AJ
May 27, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Magnavox 51mp392h
Are your colors out of convergence also? If so this is a classic symptom of bad Convergence ICs.
Jan 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
