Question about PNY 8GB Kit 2x4GB PC3-10666 1333 MHz DDR3 Desktop DIMM ECC Registered
Ram memory does not work in my computer - PNY 8GB Kit 2x4GB PC3-10666 1333 MHz DDR3 Desktop DIMM ECC Registered
  • 417 Answers
Ram does work in your pc. it works in every pc. Now the type of ram that works is the root of the problem. Basically your looking at 3 types of ram and really only 2 probably unless your pc is a dinosaur. They are DDR II and DDR III Make sure your PC uses the type you purchased. Also, make sure you have the system requirements to run that large of Ram.
Posted on Oct 24, 2012
How does ram works?
RAM is an acronym for Random Access Memory, which is the memory your computer uses to hold your operating system (such as Windows 7), your applications, and working data while the computer is turned ON. These are copied from the hard drive to RAM when you turn on the computer or run an application. When power is turned OFF, all the information in RAM is gone (it is not saved). Memory in RAM is like a matrix. Address lines on the memory chip point to a single memory address at a time, where a word (8, 16, 32, or 64 bits wide) of data is stored. When power is first applied, all memory locations store zero or undetermined values. RAM is working memory or scratch-pad memory that is used for temporary storage. Permanent storage requires either EPROM, EEPROM, Flash, Battery-backed RAM or a hard drive.
See this link:
http://www.ehow.com/how-does_4899593_ram-work-computer.html
Oct 31, 2013 | Computers & Internet
My computer has one long beep 2 short beeps, I put in new RAM and still does the same.
One, if I may; clean the gold plated contact pins with a pencil eraser, use air to remove the eraser dust. THEN try again before buying new Ram Memory.
(You are Following Anti-Static Precautions, right?)
Unplug the computer from power. Press the Power On button in, and hold for a count of 10 seconds. Let go.
Do this procedure two more times.
Plug the computer back into power.
What this does is clear CMOS Error Codes, and resets BIOS Setup back to the factory default settings.
We are just trying to clear CMOS Error Codes.
WAIT 1 minute, turn the computer on.
Still no?
'Slap' BIOS around a little bit.
Hold the Power On button in for a count of 10 seconds, or until computer turns off.
WAIT 1 minute, turn the computer back on.
I had to do this 3 times, one time, in order to get BIOS to recognize the new Ram Memory.
A) Ram Memory HAS to be in Slot 1. (DIMM 1)
That is the ram memory slot the Processor reads first.
Don't care about the other Ram Memory modules at the minute.
Just want to make sure a module is in Slot 1.
B) Are you SURE you have the correct Ram Memory?
There is a TOTAL amount for the motherboard, and EACH ram memory slot has a Maximum amount also.
Install in Slot 1 first. Try computer. If it works, then install ram memory in other ram memory slots.
No didn't work?
Then install in Slot 2.
You may find one of the ram memory slots is bad.
Regards,
joecoolvette
Feb 28, 2013 | ASUS M4N68T-M-V2 M4N68T-M V2, Socket AM3,...
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
What is the uses of the memory
Depends on what Memory you are referring to, yampratwum
1) Cache for a Processor;
A small memory area on the Processor.
(L1 and L2. Some Processors also went to L3 cache)
Cache operates at the same frequency rate ('Speed') as the Processor.
It is the First memory area the Processor accesses.
http://en.wikipedia.org/wiki/CPU_cache
http://computer.howstuffworks.com/cache.htm
http://www.hardwaresecrets.com/article/How-The-Memory-Cache-Works/481
2) Ram Memory;
Volatile memory.
Once the computer is turned off, all memory stored in Ram Memory is GONE.
Ram Memory typically operates at half, of the frequency rate of the Processor's Front Side Bus. (FSB)
It is the Second memory area that the Processor accesses.
http://computer.howstuffworks.com/ram.htm
3) Harddrive; (Hard Drive. Hard Disk Drive)
This is the Third memory area the Processor accesses.
There is also a small memory area on the harddrive.
This is it's Cache. It is called the Buffer.
http://computer.howstuffworks.com/hard-disk.htm
http://en.wikipedia.org/wiki/Disk_buffer
http://www.hardwaresecrets.com/printpage/177
4) Virtual Memory;
An area on the harddrive that Windows has allotted.
Rule of thumb is Virtual Memory is one and one-half, (1-1/2) the amount of Ram Memory.
Example;
2GigaByte (2GB) of Ram Memory?
Typically Virtual Memory will be 3GB.
http://en.wikipedia.org/wiki/Virtual_memory
5) BIOS;
Basic Input/Output System
A program that is flashed to an EEPROM chip. The BIOS chipset.
Another small memory area.
http://computer.howstuffworks.com/bios.htm
http://computer.howstuffworks.com/computer-memory.htm
Regards,
joecoolvette
Nov 05, 2012 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
MS 6368 VER 5 MEMORY
It takes SD Ram, Which is no longer available. Below is the lonk to the Specs.
Link:
Mar 09, 2012 | Computers & Internet
Is ram and memory the same?
Yes it is Ram stands for random access memory .........cheers
Jan 27, 2011 | Toshiba Satellite L25-S119 Notebook
With 512MB RAM in slot1, laptop is working fine, but when I tried to install other 512 ram in slot 2, there were no display and numlock and caplock led start blinking. Both RAM are originally shipped with...
umm .. Are both RAM memory modules the same type? You can fit different types of RAM to a computer but they may not be compatible together. Check that both modules are the same.
Other than that, it sounds as if the problem may be slot 2. This would suggest that either the RAM isn't being correctly engaged or the slot is faulty.
Switch off the computer. Put a memory module into slot 2 to see if the computer works. Try it with both memory modules using slot 2. If neither memory module works in slot 2 this indicates a fault - motherboard probably.
If one memory module works in slot 2 - but not the other module - this tends to indicate a mismatch between the RAM modules and they are not compatible together.
Aug 14, 2010 | Dell Inspiron 6400 Notebook
My computer does not work with two 2GB RAMs
I think, one, out of the two is defected. Make pair with other memory or try changing the slots and vice versa. And for dual channel memory mode, you must installed two identical memory. I mean sizes and makes may different, but bandwidth should be identical to each other.
Jul 30, 2010 | Intel DG31PR Motherboard
Pc doesn't start properly, and displays a 1 & 3 on the front panel
Memory modules are detected, but a memory configuration or compatibility error exists.
May 11, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Did not boot and with 3 beep sound
Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
Aug 04, 2009 | Computers & Internet
PNY 8GB Kit 2x4GB PC3-10666 1333 MHz DDR3 Desktop DIMM ECC Registered Logo
74 people viewed this question
Top PNY Computers & Internet Experts
David
David
pankaj rautela
pankaj rautela
Alun Cox
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
