Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Huxqvarna mower engine cuts off when you letclutch out
  • Husqvarna Master
  • 2,239 Answers
A number of causes for this, the seat switch is faulty, the block connecter onto the switch is not pushed fully home onto the switch, or there is a problem with the relay under the hood, it is a small black square box by the fuel tank, there is possibly two, just try unpluging them and swap the block connecters round, if there is a fault you will move the problem else where but it should start, in this case replace with a new relay.
Posted on Oct 24, 2012
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Why does my lawn mower start and immediately cut off? Installed new plug and filter.
How long has petrol been in mower for. Could have fuel that has gone bad in it. Also when you start mower you usually need to start with the choke activated until the engine gets warm and then take off the choke. Also check the throttle linkage as some mowers have a device that kills the engine when the throttle is pulled down to stop and it is usually on the mower engine and gets activated when you pull the throttle cable to the stop setting. Had one where this was bent. Another thing I have had is a pin that is in the drive shaft that had broken thus causing the mower shaft not to turn with the engine.
Aug 29, 2014 | Garden
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
Castlegarden twincut ride on lawn mower cutting out
some engines have a low oil level sensor yes. ck. oil level
Jun 02, 2013 | Garden
John Deere CR125 hydrostatic mower, engine runs
sounds like you have carb problems
Sep 07, 2009 | Garden
My mtd pinto mower engine cuts out when cutters engage - why?
it sounds as if your carb is dirty remove bowl on carb i"ll bet it's it's dirty if so you will need to remove the carb and clean it
May 23, 2009 | Garden
When mower gets hot it cuts off crank back up run a min cut off
1 of 2 things happening
first change the fuel filter seams that the gas is vapourizing
If that does not fix it replace the engine coil as it heats up it is breaking down in voltage causing the engine to die
Apr 05, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
44 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
