Question about Sharp Mx-5111n Multifunction Copier
How do you get custom size envelopes on sharp mx-5111
I have a customer who is trying to print their logo on a 9x12 envelope but there is no custom size button in the envelope setting
5 Suggested Answers
tehnik_bdg
  • 91 Answers
SOURCE: sharp mx 3500 won't recognize custom paper
In the printing properties, on the paper select tab, change the paper tray from automatic to by pass tray
Posted on Jun 23, 2009
  • 15 Answers
SOURCE: How do you load standard sized envelopes into a
long ways in the cassette, unless you have a bypass tray, make sure to change your cassette setting under systems settings, tray settings.
Posted on Sep 09, 2010
dwylie76
  • 80 Answers
SOURCE: how do i print 6 3/4 return size envelopes on a
You have to select the Manual Feed Tray by touching the picture of the copy machine on the LCD screen. That will then show you the paper trays. Touch the paper type soft key for the Bypass/Manual Feed Tray and then select envelope. then press ok a couple of times till you are back to the main screen. Put your envelopes face down on the Bypass/Manual Feed Tray. If you are printing from a computer do the same thing after you go to printing preference/properties.
Posted on Oct 25, 2011
  • 24 Answers
SOURCE: print 4.374 x 5.75 sharp 2300
Envelopes must be run from the bypass tray at the side of the machine. touch the paper trays on the touch screen. Set the bypass to envelope and com10. when you go to print, make sure the paper type is set to envelope under printer preferances.
Posted on Aug 04, 2012
You must have a record. hp p1006 printer envelopes hang in print que. I have spent many hours with your staff and the problem hasn't been solved?
Envelpopes should be printed using the feed tray located in the front of the printer not through the paper cassette. Try this: Follow these steps to print on envelopes from a computer running Windows. NOTE: For specific details on formatting text for printing on envelopes, consult the help files in the word processing software. For best results, consider using a label for the return address.
  1. Click File , and then click Print . The Print dialog box opens.
  2. Depending on the software program, click Properties , Options , Printer Setup , or Preferences . The printer Properties dialog box opens.
  3. Click the Paper/Quality tab.
  4. Select Envelope as the paper type.
  5. From the Size drop-down list, select the applicable size. To create a custom size envelope, use the following steps:
    1. On the Paper/Quality tab, click Custom .
    2. Click in the Name text box, and then enter a name for the custom envelope size.
    3. Click in the Width text box, and then enter the width. NOTE: Make certain the size is in inches. Click the Use Millimeters/Use Inches button to toggle between using millimeters and inches to define the custom paper size.
    4. Click in the Height text box, and then enter the height.
    5. Click Save .
  6. Click Apply to save the settings.
  7. Click OK to print the envelopes. NOTE: An error message might display asking to load an envelope into the manual feed tray. This might occur even if the envelopes are loaded. Make sure the envelopes are loaded, and then click Continue . The product will continue printing from whichever input tray contains the envelopes.
Dec 17, 2010 | HP LASERJET P1006 Printer
How do i print envelopes on the HP 1350?
  • Remove all paper from the paper tray.
  • Slide an envelope into the tray, with the envelope flap up and to the left (print side down), until it stops.
  • Adjust the paper-width guide against the envelope.
  • Be careful not to bend the envelope.
  1. In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
  2. In the Envelopes and Labels dialog box, click the Envelopes tab.
  3. Click Options .
  4. From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
  5. Click OK , and then click Close to close the Envelopes and Labels dialog box.
  6. Click File , and then click Print to print the envelope.
Dec 01, 2010 | HP PSC 1350 All-In-One Thermal Printer
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
Envelope printing
Go to custom setting, paper size setting for by pass tray, use custom measurement,input the size of the envelopes ( in X Y mode ). When you print, go to the properties and change the paper tray select from auto to by pass tray.
Good luck.
Mar 11, 2009 | Sharp MX-2300N Color Copier
I am too stupid to print an envelope
No, your not. The M24 has to be the hardest machine on earth to print an envelope on, It is the biggest headache I have ever seen in printing. Here are the instructions and good luck.
NOTE: The PCL driver is the only driver supported for printing envelopes. There is no support for printing to envelopes using the Adobe PostScript® printer driver. It is necessary to complete all steps to successfully print envelopes.
NOTE: If printing through a server, changes to the driver must be made at the server level.
To set up the custom size paper for the printer:
NOTE: The setup of the custom size paper is a one-time step. Once the custom size is setup it remains an available paper size until it is changed.
  1. At the workstation, click on [Start], point to [Settings], then select [Printers].
  2. Right-click on your printer and select [Properties] from the menu. The Printer Properties window will be displayed.
    NOTE: Use the custom size paper in the printer driver when printing within an application.
  3. Select the [Configuration] tab.
  4. Select [Bypass Feed Orientation] and make sure it is set to Portrait in order to feed the envelopes long edge feed (LEF).
  5. Select [Custom Paper Size].
  6. Select one of the five custom sizes.
    NOTE: There are five custom sizes that can be set up for use in the printer driver properties. Custom Paper Size can be given an individual name by selecting [Name]and typing the name for the custom size, such as, envelope. The name will then appear as an option in output size.
    Three types of envelopes are supported:
Type for Envelope Metric Size Imperial Size Monarch 98.4 mm x 191 mm 3.9 x 7.5 Inch Commercial #10 105 mm x 241 mm 4 x 9.5 Inch DL 110 mm x 220 mm 4 x 8.6 Inch
  1. Enter the short edge and long edge values for the envelope size you are using. The driver will now show the new custom size as one of the choices in Output Size.
  2. Click [OK].
To set your printing preferences for the printer:
  2. Right-click on the printer you want to print envelopes and select [Properties] from the menu that will be displayed.
  3. Select [Printing Preferences].
  4. Select [Tray 5] (Bypass) for the Paper Source.
  5. Select [Heavyweight 2 (170-220 g/m²)] for the Paper Type.
  6. Select the custom size you created for envelopes for the Output Size.
  7. Click [OK] twice to exit the Printing Preferences and the Properties windows.
To print envelopes at the workstation using Microsoft Word®:
  1. Open your Word application.
  2. Select [File] on the top left of the toolbar.
  3. Select [Print] from the menu. The Printer window will be displayed.
  4. Select the printer that you will use to print the envelopes. This printer will use the same driver where you defined the custom paper size.
  5. Select [Close].
    NOTE:If you do not select the correct driver you will not be able to select the correct paper size in Page Setup.
To print envelopes at the workstation using Microsoft Word Page Setup:
  3. Select [Page Setup] from the menu. The Page Setup window will be displayed.
  4. Select the [Paper Size] tab.
  5. Use the paper size pull-down to select the paper size you defined in the driver. The paper size will be listed by the name you gave it in the driver setup. The default will be custom 1, 2, 3, 4 or 5.
  6. Make sure the orientation is set to Landscape and select [OK]. At this point edit the page with the information you want printed on the envelope.
  7. Select [File] from the toolbar.
  8. Select [Print].
To load envelopes at the printer:
Load the envelopes into Paper Tray 5 (Bypass Tray). The orientation needs to be long edge feed (LEF) with the flap closed and the flap side at the lead edge, and the print side facing down. The printer is now set to print on the envelope.
NOTE: Load a maximum of 10 envelopes into Tray 5 (Bypass Tray) at a time. You may be able to fit a few more depending on the envelope's thickness but do not exceed the max fill line on the tray. The envelope may wrinkle depending on its weight and stiffness. The machine is not designed to handle high-capacity production envelope printing.
Feb 09, 2009 | Xerox WorkCentre M-24 Color Copier
Envelope printing
With the address highlighted go to Tools, Envelopes, Custom
Enter the custom envelope size
Pick #4 feed method
click OK
Set the feed tray to hold the envelope along the right side.
Insert the envelope with the flap up - push it all the way in.
Print it
Dec 18, 2008 | HP DeskJet 6122 InkJet Printer
Printing envelopes on the bizhub 252
After spending way too long messing around with this on my bizhub 250 here's what finally allowed me to print:
I simply changed the bypass tray setting from "envelope" to "normal". I kept the custom size the same (9 1/2 X 4 1/8) and it started to print.
Doesn't make sense, but you can give it try.
Dec 27, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 200 printing custome envelopes
Do not know if this helps, but I could not print Com 10 envelops until I said the type was "normal" - Type "envelope" would tell me I had the wrong size.
Dec 12, 2007 | Minolta bizhub 200 All-In-One Printer
Sharp Mx-5111n Multifunction Copier Logo
113 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
