Question about SanDisk SDCZ50-032G-A11 32GB Cruzer Blade USB 2.0 Flash Drive SDCZ50-032G-A11
Data copy san disk .but anather computer connect not show data
  • SanDisk Master
  • 27,725 Answers
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
An example on how to safe documents , photo's or data to a usb drive
click start all programs accessories open windows explorer navigate to your photos
right click on the documents , photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photo's to your usb drive then drop them
or if you are downloading data or programs from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope it helps
Posted on Oct 24, 2012
3 Suggested Answers
  • 389 Answers
SOURCE: my san disk 2gb pen is canot open but light is
USB Pen or stick drives usually use the letters "F" or "G" drives on your computer. If these drive letters are being used, the USB drive will not be available. Also, if this is the first time you are using the USB drive, it is possible the drive is not formatted. Although this is unlikely.
I will outline instructions below to use the Disk Management tool in windows to see if the drive shows all the drives connected to your computer. If your computer is recognizing the drive as you describe. I am confident USB Pen drive will show up in disk management. You may be able to assign a drive letter and make the drive visible in you my computer window.
The directions for using disk management are listed below. A note of caution, do not make any changes on you Disk 0. or "C" drive, as this is you main hard drive that starts your computer.
Right click on you “My Computer” Icon
A menu will open
Chose “Manage”
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu. The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have no disk will not show as active drives on the top section, but can be seen in the lower section.
The lower shows each drive, their drive letter and status. The left section will have small boxes showing drive numbers. Drive 0 is usually your main hard drive. To the right of the smaller section is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show “healthy”) This is the area you can right click and get a menu that will allow you to: open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition.
In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows. A drive this is having a problem may show that it needs to be formatted. This can be done from this window as described above.
Please follow these directions and see if you can make your drive visible. If you have any questions about the instructions or need further assistance, feel free to reply to this message and I will assist you further.
Brian
Posted on Jan 29, 2010
bronk50
  • 27725 Answers
SOURCE: Hi..trying to retrieve data from...San
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Posted on Aug 12, 2011
Dynex dx-hu 823 and san disk connection
Kindly look through the operation manuals of both and follow guidelines step by step.
Aug 01, 2012 | Televison & Video
I have a san disk cruse 16GB pendrive , it is not getting formatted and showing 64.00MB capacity...
I have a san disk cruse 16GB pendrive , it is not getting formatted and showing, but it is showing 0 bytes. can anyone help me..?
May 01, 2012 | SanDisk 16Gb USB Flash Drive
I have a san disk 2gb memory card for my nokia phone, i took my memory card out for the first time as i wanted to put the pictures from it onto my computer, everything worked fine, however when i put my...
you can not format your card without loosing data on it. The solution is to copy all the data to your computer, format the card (in your computer, still) and then copy the data back.
Hope this helps,
Lucas
Jul 10, 2011 | SanDisk 2GB microSD Memory Card
I want to save the files on my gigaware flash drive that needs to be reformated. How can I save my files? I have adobe, word, and powerpoint presentations saved to the drive.
make a folder on your C: drive, name it what ever (San4) stick the San Disk in your usb port. get up my computer, find the San Disk, right click on it, on the open menu find "copy" and click on it. then get up your C: drive, find the folder you made (San4) right click on the folder and select "Paste" from the menu and every thing on the San Disk will be copied to a file called San4 on your "C" drive
Jan 11, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I need basic instructions how to save data on the san disk,
Hi and Welcome to Fixyah,
To save data on your sandisk all you have to do is to connect that to your USB, When you want to save it just click on the file that your want to save then hit save as then browse for the removable disck icon open it and then save. Copy
Aug 10, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Apple ipod 8G Model# A1285 Shows songs when connected to PC, but when I disconnect it show 0 songs. Please Help.
i have ipod modle A1285 when connect on computer all data show but when disconect for pc no show song video and much more why please sulution me
Feb 27, 2010 | Apple iPod nano
How do you downloade videos to the san disk
you need to verify first the capacity of your san disk.a movie is usually 750 mb in avi format.
if your san disk has the capacity just save the downoaded file on a folder in your computer first.
when finished download just copy and paste in the sandisk (removable disk) directory.
Oct 03, 2008 | Televison & Video
San disk error
Replace the card
Oct 22, 2017 | Cameras
Computer won't recognize san disk 4gb ultra
Since your card is password protected,computer will not recognize it..so remove the password and then try it will work..
_______________________________________________________
Thanks for using fixya technical support
Jun 17, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
SanDisk SDCZ50-032G-A11 32GB Cruzer Blade USB 2.0 Flash Drive SDCZ50-032G-A11 Logo
66 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
