Question about Sharp R-1480 Microwave Oven
Door Disassembly I have to replace the latch spring hook inside the door and must take the door apart. There are no visible screws which makes me think its snap together. I don't want to damage the door, how does it come apart so I can replace the latch. Thanks
  • sadkkf Dec 03, 2007
    I've encountered a similar problem in that the door will not close. Opening the enclosure on the door, I see the spring and the hook component are in tact, but the piece attached to the other end of the spring is broken. This piece was part of the outer door. Super glue didn't work. Is it possible to purchase the outer door only or is there a way to fix this?
  • Anonymous Mar 28, 2014
    The handle snapped off the door to the microwave leaving broken plastic piece stuck around the pin/screw inside the now visible holes on the door where the handle used to be. There are no visible access to the screws from the back side of the door. Do I need to tale the door apart to install the replacement hanle that I purchase? is there a manual that shows how to replace a broken handle?
  • Sharp Master
  • 9,156 Answers
Actually, the spring is probably okay. What breaks is either the latch head (with the hook-like protrusions) OR the spring mounting tab on the inner side of the outer door panel. The spring connects to both of these parts. The outer door panel is not availablke as a separate part, so if that's where the break is, you'll have to get a bit creative and clean it squeaky and use epoxy (like JB Weld, but never use "super glue") or you can drill into the panel slightly and install a small screw eye or glue it in place. Even if the spring mount on the inner door panel is not yet broken, while you're in there, it's a good idea to clean it squeaky and add some epoxy to strengthen it. To get to the screws, you have to remove the choke cover (see sample photo below). It's usually not necessary and is better not to remove the door. You can set the oven on its left side on a table top, open the door carefully, and ease it down to the table top. Then you have a level, stable area to work on the door. If the problem is the latch head (ref # 5-2-2) then I would recommend replacing that part instead of gluing it. That's because the new part may be an improved version. Plus you'll start out fresh. The part # is LSTPPB030MRF0 (zero on the end, not an "oh") You can order Sharp parts from http://wwww.wehaveparts.com You can find a helpful exploded view of the door here: http://207.234.249.73/mwd/r1480_control_door_exp.pdf
Posted on May 11, 2007
  • William Miller
    William Miller May 11, 2007
    CORRECTION:
    A JPG version of that exploded view of the door might be better.
    It's here:
    http://207.234.249.73/mwd/r1480_control_...
Drilling a little hole from the inside-out and putting a little screw did the job in 10 minutes. Awesome recommendation. Thanks.
Posted on Jan 27, 2008
SOURCE:
GE JVM1660 spacemaker XL microwave
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We have critical safety & disassembly info at our site.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Apr 25, 2010 | GE JVM1660 Microwave Oven
Door will not close
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
We have critical safety & disassembly info at our site, linked here.
We may have the service manual, and if so, we can give you a link to download it free.
Jan 30, 2010 | Sharp Microwave Ovens
How do i take the door apart to replace the latch spring on my sharp carousele r 1480
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jul 09, 2009 | Sharp R-1480 Microwave Oven
Sharp R-308J microwave door will not latch
If you gently push up on the door latch head assembly (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Jan 11, 2009 | Microwave Ovens
Microwave broken door latch
The door latch head (hook) is pretty easy to replace or repair if that's the issue.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a panasonic slimeline combi microwave and the plastic hook which helps keep the door locked is broken, therefore the microwave will not work
Of course the door latch head (hook-like device) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
Sep 23, 2008 | Panasonic Microwave Ovens
Door does not latch close on the Panasonic Microwave Oven Model No. NN T444SF
Aug 26, 2008 | Panasonic Microwave Ovens
The safety door latches no longer latch.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Aug 11, 2008 | Sharp Microwave Ovens
Hi, our panasonic genius microwave door won't latch shut, thus preventing us from using it. Is there an easy fix for this?
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Microwave Ovens
Door will not stay closed, panel reads "Refer to operating instructions before use"
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
We have critical safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 05, 2008 | Panasonic Microwave Ovens
Sharp R-1480 Microwave Oven Logo
642 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
