Question about Whirlpool Dryers
Dryer does not run, but heating is fine
A whirlpool dryer just stopped running yeasterday. The heating is fine.We do not know where we can find the fuse which may be broken.
    Scholar:
  • 86 Answers
Hi, I hope i am getting this right? The t/dryer still heats but does not turn? If this is the case then it will be the drive belt that is broken and will need replacing.Easy job. Take the top off and have a look and see if there is any sign of a belt in there...
Get back to me.......
Posted on Jan 02, 2009
My whirlpool gas dryer stops running.It stops with heat or no heat.I have held the door switch with the door open and it still stops.Sometimes it will run a minute sometimes a few seconds
If it runs when you hold the switch but intermittently when the door is closed, you might need to either replace the switch or the toggle on the door. See if you can bend or adjust the toggle on the door that closes the switch to fix it or if you can't, try replacing it first since it is the cheapest solution. Switch, based on what you posted, sounds fine. Who knows, maybe one is simply depressed from slamming the dryer door closed too many times?
Jan 15, 2018 | Whirlpool Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer model LGQ80000JQ4 starts to heat and runs then stops heating, but rest of dryer seems to run fine
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Sep 18, 2009 | Whirlpool LGQ8000JQ Gas Dryer
Dryer runs when first started, quits halway through drying cycle.
High temp. limit is probably at fault and will need to be changed.
Jul 13, 2009 | Whirlpool Dryers
Whirlpool ultimate ii electric dryer stopped heating
change out the heat element, you can get the part at Sear
Nov 27, 2008 | LG DLG2524 Gas Dryer
Whirlpool Gas Dryer - Model LGB6200KQ1 Serial # mm2105815 Heat comes and goes. Can heat fine for a few loads then stops. Then starts again. Any ideas
Sounds like it is running Hot, Clean you venting out and make sure the weather hood outside is not blocked.
Vacuum out the lint filter area.
Your dryer also may have worn seals, how old is it? 10 to 12 years running a load a day average? it may be time for a new dryer or rebuild yours.
Jul 10, 2008 | Whirlpool Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
