Question about Simpson Esprit 750 Top Load 7.5kg
My machine fills and rinses but it does not agitate or spin i have a simpson esprit 750
My machine fills,empties and rinses but it wont agitate or spin.
  • 6277 Answers
SOURCE: esprit 750 wont spin cycle
Probably struggling to drain properly
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 17, 2011
tanda400
  • 7 Answers
SOURCE: simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
Posted on May 04, 2012
kevin_getz
  • 1031 Answers
SOURCE: Hi, I have a simpson ezyset 550 which won't stop spinning.As soon as i turn the machine on the agitator spins continually.Any ideas?
Most likely the brake on the bottom of the tub isn't engaging.
Posted on May 21, 2012
  • 713 Answers
SOURCE: My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Posted on Jul 14, 2012
  • 389 Answers
SOURCE: my washing machine Simpson Model no 22S711 wont turn off when it is filling up with water
if it stops when you turn the machine off the problem will be that the pressure switch chamber is blocked unblock it should be ok
Posted on Sep 30, 2012
How to remove agitator from Simpson 750 esprit
Look down inside the agitator. At the bottom is a hexagonal bolt. You need a 10mm socket on a long extension bar to reach it and undo it. Then pull agitator up & out.
Feb 15, 2017 | Simpson Washing Machines
I have a Simpson esprit 550 and it won't agitate or spin? Fills and drains fine any help would be great thanks
check pressour switch door lock or lid lock not familer with mechine so don't no if its top or front loader good luck
Apr 20, 2015 | Simpson Washing Machines
How do i replace a programm switch on a simpson 750 esprit washing machine
Normally, you would push in on the knob to set to a cycle then pull out on knob to start machine. Am i correct? So when you push in to set the cycle it just spins?
Jan 27, 2013 | Simpson Esprit 750 Top Load 7.5kg
Main power flicks off when starting my simpson esprit 750 washing machine
Hi just read your posting,Now there are two types of Simp esprit,Is yours a top loader or a front loader? Does the machine trip the fuse when you select the spin cycle or only when it starts to fill?Have you tried putting it on a spin cycle?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Aug 28, 2010 | Washing Machines
Simpson Esprit 650 - Won't agitate
Our machine , same model, was doing the same. Had a repairman cone out & it was the Motor Control unit, seems to be a fairly common problem. But now its fixed & working well.
Dec 27, 2009 | Washing Machines
Washing Machine won't stop filling and then won't stop emptying
Does your machine fill with water even if the machine is off? In this case your inlet valve at top of machine is defective & can be easily replaced (will tell u where to get spares, if your dealer cannot) by yourself.
If water does not stop, after filling machine at a low level(is this a front loader?) and is flowing away - check your exit pipe, it has to have a certain height (approx 3 feet) up before going down to your drain pipe.
Feb 24, 2009 | Washing Machines
Washing Machine, Simpson Brand, Esprit 750
Hi Angelina
I am having exactly the same problem. Did you replace the timer, if so did it fix the problem?
Thanks,
Sheryl
Jun 05, 2008 | Washing Machines
Simpson esprit washing machine
put a new pressure switch in it
Mar 25, 2008 | Washing Machines
Washing Machines Logo
Top Simpson Washing Machines Experts
Owen Barnes
Vernon Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
