Question about GE WJSR2070B Top Load Washer
GE WJSR2070B2WW will not stop at end of cycle. If I put it to the end of the cycle and close the lid, it tries to run but won't. If I set it to a cycle it will begin filling. Came home and found it stuck in the spin mode for several hours while away. Thoughts?
  • 14 Answers
SOURCE: washer will not stop spinnig
You probably have a blocked pump. Pull it out and clear the obstructions- buttons, lint, etc
Posted on Sep 11, 2007
  • 7 Answers
SOURCE: washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Posted on Dec 22, 2007
SOURCE: Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Posted on Mar 25, 2009
SOURCE: will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
Posted on Aug 18, 2009
  • 14 Answers
SOURCE: water runs but doesn't fill tub and wont spin if put on spin cycl
The drain hose must be higher than the tub of the washer so many times I get called to find the hose on the ground to the drain an this will not let the tub fill.
Posted on Jan 28, 2010
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
GE Top Loading washer doesn't aggitate properly.Model # WJSR4160DW
Reach into the washer and try to turn the agitator by hand and if you can turn it freely the agitator coupling (sometimes called the air bell) is stripped out. If that isn't the problem let me know. Here is the part should you find it bad.
Nov 02, 2012 | GE Washing Machines
Ge washer "lo" light when lid is closed. and won't start after it has run before
"LO" means the washer's lid is not closed
What is the model number?
Oct 13, 2012 | Maytag Washing Machines
Machine won't turn on Hot Point washer, checked outlet ok
Have you tried to run it for a cycle? What exactly does not come on? Is the lid totally closed?
Apr 03, 2012 | Hotpoint VBXR1090D Top Load Washer
Whirpool washer LSN1000JQ1 topload won't drain .
check the lid switch,open the lid,stick a screw driver into the hole where the strike on the lid closes into,you should hear a clicking sound,no click the lid switch is bad,or close the lid and open it up a few inches and close it down,no clicking sound the switch is bad.you can watch this video and it will show you how to change the switch
http://www.youtube.com/watch?v=V5aW9WkTFhEif the part number is 3949247 and the lid switch is around 50 dollars,common problem.if you hear the switch click when you stick the screw driver into the hole set the timer to spin,pull out the timer knob and then stick the screw driver into the hole again,if the switch is engaging it will drain and spin but if it doesn't click change the switch.good luck,if you need anymore help let me know.
Mar 13, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
Will not go in to spin cycle
May 09, 2009 | GE WBSR3140DW Top Load Washer
Washer will not stop spinnig
Jun 02, 2006 | GE WJSR2070B Top Load Washer
GE WJSR2070B Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
