Question about Toshiba 43H71 43" Rear Projection Television
Toshiba 43H71 It appears that I have a convergence issue(can not move the red gun up or down. I have read several problems pertaining to this and it appears I need to replace the STK's chips and possibly the resistors. I work on computers so component replacement is not new to me. Where are these chips located? Can you send me a picture showing the components or direct me to the proper location? Is there a number I should call to order these chips? A local TV shop said they have a number but I'm not sure if I need the part #'s first. I'm aware of the heat sink compound needed to dissipate the heat. Any help on this matter would be greatly appreciated.
  • John Walker May 22, 2007
    I was able to fix this problem by replacing both STK392-110 along with all six 1.8 ohm 1 watt resistors.(R7711,R7721,R7716,R7726,R7736,R7731). I put the white heat sink grease on the chips and double checked to make sure my solder joints were good. I reconnected all the connectors and tested the unit. After running the convergence setup it works fine. Thanks again for all your help.
    P.S. I used Sanyo chips bought at B&D enterprises www.bdent.com. After all the work you have to do why take a chance on a generic part just to save a few bucks. Quality matters.......
Hi, I am having the same exact problem. Finally found this. I ordered the parts and will be performing this when they get in. http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on May 11, 2007
I just moved my 42in. Toshiba rear projectiom Tv from my basement to the upstairs and now my convergence is off. The red tube cross is low on the manual adjustment and will not go up to the other colors.IT...
It sounds like you jostled the red CRT gun when you moved the set. If the convergence adjustment still moves the red cross hair the the circuitry is okay. Your red gun needs to be realigned. This requires a service call unless you want to attempt it yourself. It is fairly involved and requires some specific tools as well as using the service mode on the remote to reset the convergence after the gun is repositioned.
Dec 06, 2009 | Toshiba 53H71 53 in. Rear Projection...
Picture problem
The convergence amps need replacement in your tv...
Oct 10, 2008 | Toshiba 43H71 43" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
RED Convergence Alignment issue
Replace both STK392-110 Convergence IC's with Toshiba or Sanyo quality................No cheap IC's !!!......................T.
Aug 16, 2008 | Toshiba 43H71 43" Rear Projection...
CONVERGENCE PROBLEM IN TOSHIBA 43H70
Replace both STK392-110 convergence IC's with Toshiba or Sanyo brand........no cheap junk IC's !!!.................T.
Convergence
you can replace IC stk 392-110 (one or all) and tray to adjust R_G_B
Nov 25, 2007 | Toshiba 43H71 43" Rear Projection...
43H71 43 In Projector
Use Toshiba STK392-110T X 2 for exact replacement..........T.
Nov 21, 2007 | Toshiba 43H71 43" Rear Projection...
Red is off
This is the typical convergence problem you will read about over and over on this website. You need to replace 2 amplifier IC's part number STK392-110 and check all of the resistors in that circuit.
May 11, 2007 | Toshiba 43H71 43" Rear Projection...
How to adjust red blue green
if ur in service mode already..turn down all drive.green first turn it up until the desired intensity is achieve.then blue all the way until it almost blend the green.u must not see one color either too much green or blue.turn up red now,let it blend until u see a perfect black and white.note:make sure that the color level is set to minimum and tint to center. ihope i help u..
Mar 20, 2007 | Toshiba 43H71 43" Rear Projection...
Vertical Red/Green lines
You have bad connections on the board and need to be resoldered or the convergence IC's are bad. If you know how to solder on solid state elctronics then you can change the IC's or find a bad connection on the board if you know the High Voltage issues when working on a TV set. If you have to training on TV sets I highly recommend that you call a service person to assist you in this repair.
Sep 25, 2006 | Toshiba 43H71 43" Rear Projection...
Toshiba 43H71 43" Rear Projection Television Logo
231 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
