Question about Yelo 800DVD DVD Player
Problem playing region 4 dvd's
I have a Yelo 800 dvd, i thought this was a multi region player, I have received 3 dvd's from my brother in Australia all region 4, when trying to play them it is coming up as no disc....I have used the hack code through the remote to gain access to the factory settings and then change it from multi region to region 4....but when attempting to play the dvd it comes up with no disc again! I am at a loss as to how to play these discs through the Yelo!
Many thanks
Simon
Sorted it....followed following and changed to region 4 instaed of open to all regions and the the dvd's worked! Not sure why I had to change from multi-region to sole region 4 but why question when it works! Thanks
press remote keys in this order- open-setup-mute-last-next-this opens the service menu where you can select ALL regions or in my case changed to region 4 only!
Posted on Jan 04, 2009
How can I change the region settings on my Sony DAV DZ870W many thanks, Shane
When a DVD disc is created, it is encoded with a "Region number." The disc will only play on DVD players with the same Region number - for instance, a Region 3 disc won't play on a Region 1 player.
Region 1: U.S. and U.S. Territories, Canada
Region 2: Japan, Western Europe, Middle East, South Africa
Region 3: South Korea, Hong Kong, Taiwan, Southeast and East Asia Region 4: New Zealand, Australia, Pacific Islands, Mexico, Central/
South America
Region 5: Russia and the former Soviet Union, Africa, Indian
subcontinent, North Korea Region 6: China
The only way to get around the region codes, is to rip a DVD to your computer and remove the region code. Then burn the DVD to a DVD R. There are programs around on the net, but I'm not sure it is legal in all countries.
Google for the programs.
A DVD player sometimes allows you to change the region code once. But it not even would allow you to switch back after you changed it once.
Jan 26, 2015 | Sony Televison & Video
How do I unlock my blaupunkt tv/dvd combo for multi region dvd's
South America
Oct 27, 2014 | Televison & Video
Region code
South America
There are computer programs capable of remove the region code from a DVD, but the result should be burned on a new DVD. Most players don't allow a change in the region code more than once. So on your player nothing to hack. Sorry
For all other options, please use Google.
Jul 16, 2014 | Televison & Video
What region is the DVD player that comes with the new TEAC TV that I bought? I can't find the info on the manual or the internet. Please help. I live in Australia. Thanks.
It depends if the DVD player is separate to the TV or built into it. Assuming the DVD is a separate unit, it must be region 4 for Australia, unless specified otherwise (on the player's rear panel or in the operation manual). The only types of DVD players/recorders allowable in Australia are region 4, and multi-region. If the player plays region 4 DVDs, but not other regions, there's your answer. A model number and/or brand of the DVD player would help.
May 17, 2011 | Televison & Video
Will the dvp 311ok play ntsc dvd i am in australia and i am reg 4
As long as the NTSC DVDs are not region coded, and your TV is multi-standard (able to receive NTSC as well as PAL signals via A/V inputs or similar connections), the player should play NTSC just fine through it
I assume this is a PHILIPS player? If so, most PHILIPS DVD players support NTSC playback on PAL TV.
You are correct, Australia is region 4 for DVD standard. The only restriction would be region codes.
Feb 27, 2011 | Televison & Video
Philips mini DVD PET702/75 multi region unlock code
To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the “SETUP” button on remote control,
then select the “Preference MENU”
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
moz-screenshot.jpgmoz-screenshot-1.jpgRegion
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select “0” setting = Region Free (confidential)
Feb 28, 2009 | Philips Televison & Video
Region problem with LG DVD RH265
no problem! I just bought a LG RH265 and made it multi region with no problems:
on your remote-
1) press HOME
2) move to SET UP
3) scroll down to LOCK (no need to enter LOCK options)
4) press "0" seven times
5) a message will appear stating the dvd player is region free.
6) ENJOY!!!
Dec 10, 2008 | LG LST-3510A DVD Player/Receiver
Is it multi region already?
not u would have to set the code to 0 all sum do sum dont usally need a unversal region free player out of box to do it
Feb 03, 2008 | Sony DVP-NS305 DVD Player
Panasonic dvd-cp72
asptroy,
hi mate, just want to know first if what region indicate at the back of your DVD player? the reason why i ask you, is because most of branded DVD have their own region for ex. for asian countries they are tagged as region 3 and Australia region 4 ...... most probably your player is not configured to play multi region disc if it can't play any disc. The only way to check if your player have a problem is to check the region of your player and if you can barrow or buy a dvd disc having the same region. or simply check for DVD disc which indicates that it is a all region compatible. Actually this is only info that i can share, but if your only near in my place i can help you change your dvd player to become a multi disc reader simply by clicking some activation keys using the special remote control specially design to configure and modify region setting of panasonic players.
cheers,
markiez23
Jan 05, 2008 | Panasonic DVD-CP72 Multi-disc DVD Player
Yelo 800DVD DVD Player Logo
399 people viewed this question
Top Yelo Televison & Video Experts
Electro Med Services...
Are you a Yelo Televison and Video Expert? Answer questions, earn points and help others
