Question about Sony KP-57WS510 57" Rear Projection HDTV
Red Convergence Bowing
I have this same model with a convergence isse dealing with only the Red color. Both green and blue line up perfefect but only the red is bowing, concave. The convergence chips are STK392-560 and it shows them to be 3 channel. I tried switching the two chips around expecting to see a change still had the same result. The chips are getting the voltage applied (22V) but I'm not understanding how just that one color is off. Could this be in the signal area?
  • Sony Master
  • 3,459 Answers
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Posted on Jan 27, 2009
My rear projection tv used to have green lines , now the color seems off and now its blue lines... How do i fix it. Color going out??
If colors are skewed or looks 3d it is a convergence problem.
Some sets when the convergence grid is called up will have green lines--green is fixed and red/blue adjusted to it.
To tell you how to fix I need to know brand and model number.
These are typical convergence problems--no two sets will look exactly the same.
May 16, 2012 | Televison & Video
PICTURE IS BOWING INWARD AND THE COLOR . LIKE PERSON FACE IT WILL HAVE A SHADOW OF RED, BLUE, GREEN, YELLOW
Tv have a problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced on the tv convergence board to repair the convergence problems.The shop,will cost u $300,350 for parts and labors.
Sep 14, 2010 | RCA HD52W58 52" TV
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Zenith R57W46 bottom bowing and color off and double lettering
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
Bowing at top and bottom, can't adjust convergence replaced IC
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 22, 2009 | Toshiba 57H81 57" Rear Projection...
Big screen tv
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jul 05, 2008 | RCA P52937 52" Rear Projection Television
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Bowing at the bottom of the picture
your convergence ICs need to be changed both of them. You can get replacements at the following and they include free installation instructions with free onkine tech support when you do the repair. heres the link your model should take STK392-110 or STK392-120 which interchange but the 120s are a better chip.
http://servicemanuals.vstore.ca/
Apr 04, 2008 | Philips 55PW9363 55" Rear Projection...
Mitsubishi Vs-6047 Convergence Problem...Please Help!
usally convergence green is split between 2 ics. so if your blue and red are still good. it might be the green output resistors. The
Jan 08, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
122 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
