Had to reset and now non Apple laptops connect wired and wireless, iphones and ipads will not
SOURCE: actiontec GT701-WG won't operate wirelessly
You'll probably need to turn on the wireless inside the configuration. go to 192.168.0.1 in your browser and head to advanced. From there you'll see it :)
SOURCE: Unable to Access GT704WG Router with Laptop
normally there is a small hole for reset to factory default, just put a pin inside...
Other than that, u can also connect using network cable and access the router configuration, inside, u can edit the wireless security keys
SOURCE: need to find existing WEP ID, do not want to reset my WEP ID
Flip over your ACTIONTEC and you would see there the default wep key. If you've had it personalized before, you have to open the configuration page of your modem and check for the wep key.
To go to the configuration page, open your internet explorer and type in 192.168.1.1 on the address bar. that is the default address for your actiontec. type in your username and password when prompted. the usual default it ADMIN for username and PASSWORD (lowercase) for password. or you could also try ADMIN (uname)-ADMIN(pword).
click on the wireless settings icon and then click on basic security settings. scroll down on the middle of the page and you will see there your wep key.
if you are unable to open the configuration page because you forgot your username and password, you can reset your modem so that it the uname and password will go back to its factory default settings (admin/password). However, if you are using pppoe connection (authentication using username and password to connect to network) you can lose your connection and you would have to configure your router. so be careful not to press the reset button at the back.
SOURCE: actiontec wireless router - not connecting to the internet
It will not let me sign into MSN messenger.
