Question about HP Office Equipment & Supplies
My HP psc2110 is not working. making a tractor noise when I start it. Any ideas?
  • Jason Edinger May 11, 2010
    Hey, can you rate our chat session from last week please? Thanks.
  • 679 Answers
Is the printer making grinding noises? If so, spare parts may be a problem. If there are no 'evil' noizes, remove the rear access door and clean the feed rollers with a damp cloth. If that restores paper feeding, use rubber rejuventator.
http://www.fixyourownprinter.com/kkx3.html
Posted on Jan 02, 2009
Drive belt making noise how to adjust
how do I stop the noise when i let off the pedal you have to push in to start the mower it makes a bad noise . but when I push it in it stops. how do I remove the lower deck to get a look at drive belt.
Feb 18, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
It wont start it just makes a clicking noise
if it is making a clicking noise then it is getting power to the starter. that is good. saves a lot of time. make sure the battery if fully charged. the wires on the battery terminals and the solenoid are know to get corrosion on the. be sure to take apart and clean with sandpaper to get a good connection. if it still does the same thing. the starter may be bad, or the valves may need adjusted. you will find videos on you tube that show how to do this. i hope this gives you an idea of how to get it going. good luck
Jun 27, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower won't start. Makes clicking noise.
Check the battery terminal connections for cleanliness and that they are free of corrosion. If the contact is corroded, this is what the clicking would be from.
The battery could be charged, but if the connection is dirty, the power won't be able to engage the solenoid properly.
Hope this helps.
Jul 24, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Key start on lawn mower does not work
Check your starter fuse..follow ignition wire to starter..there is a fusable link inline. make sure u have power all throughh line to starter. :)
Sep 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Tractor won't start after wrong fuel used, drained, etc
Check the fuel shutoff solenoid (on the bottom of the carburetor -- has a wrie plugged onto it) -- it may be sticking.
Spray carburetor with carb cleaner. Then if you can get it to run long enough to do any good, put carb cleaner in the fuel -- follow mixing proportions on the label.
If this doesn't work, need to take carb apart and thoroughly clean it.
Charlie
Aug 29, 2009 | Garden
88 people viewed this question
Ben Johnson
