Question about Zanussi 24 in. ZSF6120 Free-standing Dishwasher
The water wont heat in the dishwasher
Its not my machine and it was half striped when I arrived there but they told me that the water wasnt heating and that the water preasure was bad too.
  • shane casey Jan 03, 2009
    Thanks very much for your help. I will try that.
    Shane
    Scholar:
  • 86 Answers
Hi, well i think you might have your hands full here! You could be looking at a couple of faults with this. If it wasnt heating then the first p[lace to look is defently the heater and components first! But you should also check that it is filling up to the correct level to or other wise it might not switch the heater on! I know that zanussi have some problems with the sump operated pressure switches which allow the correct amount of water in before it starts to heat, so maybe look at this first. Most of the sumps can be cleaned out easy but some need a replacement sump to be fitted.
Posted on Jan 02, 2009
Ok so my dishwasher wasn't heating the water and wasnt completing a cycle and throwing up a code 3 ....I changed the element which heated the water first time but it has now gone back to not working
Seems it may be switch related. More info please. Thnx
Oct 31, 2012 | Dishwashers
Omega DW501XA Dishwasher
see this cause: Water-heating cycle the water must be pre-heated , the heating element can be faulty Timer: timer is defective, clean the contacts, see loose wires, break, or burn and repair wires. or replace timer.
Jun 19, 2012 | Dishwashers
The intake drain light is flashing and there is water in the bottom of the washer that wont drain
I had the same problem. Went through every troubleshooting tip I got. Cleaned the catch filter, checked the drain for blockage, checked the impellor to see if it was free. All was fine. Turned power off, turned back on, selected cycle and heard 1) the water drain. 2) the draw of fresh water into machine. ) all became silent and after several minute, the drain light started to flash. After getting frustrated with this isue I called Miele, they did a diagnostic over the phone by having me push a series of buttons on the panel a certain way. My machine was diagnosed by MIELE as having a bad relay switch. I was told 90 dollars plus 175 install and tech visit. I agreed. When the tech arrived he did his diagnostics, he told me MIELE reps on phone were wrong. He told me I needed a new water pump at 385.00 plus 175 install for a total of 560.00 I told him no way would I ever spend 560 + tax to repair a machine that I paid 1900 dollars for and was 4 years old. I told him I would buy a 600 dollar Samsung first before I gave him 600 for a repair. He felt his job was complete and I wasnt buying the pump story. I started questioning various things and brought up what would the appropriate soap and measure amount be for it. I told him we were currently using the Electrasol gel balls. THAT IS WHEN HE SAID, THE REASON FOR MY MALFUNCTION WAS JUST THAT. I WAS TOLD POWDER ONLY IN SMALL AMOUNTS, NOT GEL PACKETS !!!!! The gel was not dissolving completely and gumming up the impellor making it hard for it to spin. 3 weeks later machine has worked flawlessly. If you are using gel PLEASE STOP. Also I was told to squirt rinse aid in the opening under the screen, there is a **** towards the back. Remove handle and screen from inside tub. see a 2 inch wide opening, squirt the rinse aid , a small amount in there and leave overnight. This rees up the gummy residue in there. Manually run your water until its hot. And run a cycle GOOD LUCK !!!
Oct 03, 2010 | Miele Incognito G818SCVi Built-in...
Normal wash cycle is over 2 hours?
Hello there
If your dishwasher's cycle times are too long, check these: Water pre-heating Cycle not completing Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater. Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jul 19, 2010 | Kenmore 16919 Built-in Dishwasher
Water only heating after 1 and a half cycles, why?
It needs to be hooked up to the hot water. The machine will only raise the temperature about 20 degrees or so.
www.appliancehelponline.com/servicemanual.html has a video on the proper installation.
Mar 31, 2010 | Dishwashers
Water wont heat up
If your DW has an "energy saver" or "no-heat" button for wash or rinse, make sure it is not selected.  If that is not the case then the heating element is probably burned out and needs to be replaced.
Jun 02, 2009 | Beko 24 in. D3421F Free-standing...
Solution for Thermado DW245ub dishwasher
You don't have enough hot water coming into the didhwasher. The element is coming on to heat the water. Are you using the sanitizing cycle? Vitally
May 13, 2009 | Thermador DWU244 Dishwasher
Dish washer
Water pre-heating
Water pre-heating
May 14, 2008 | EuroTech EWF150 Front Load Washer
Dishwasher not heating water
British machines are Cold water fed, and the machines heat the water themselves. American Machines are hot water fed.
Nov 05, 2007 | Dishwashers
Zanussi 24 in. ZSF6120 Free-standing Dishwasher Logo
406 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
