Electronics - Others Logo
Fred S Haider Posted on Oct 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shot with Lexar Professional 233x 16 GB compact flash but can't retrieve images.
Flash card insert to card reader and connected to USB of my Mac Book Pro but source is not recognised. Now in camera (Nikon) a note comes up saying unreadable may be corrupt. How can I recover the images taken during my trip?
Anonymous
Level 3:
  • Master 2,878 Answers
  • Posted on Oct 24, 2012
Anonymous
Master
Level 3:
Answers
2878
Questions
0
Helped
487968
Points
8243
Connect compact flash to a Windows box. Check Disk with Repair and Fix.
Go to Start > Run (Search). Type cmd ENTER. From the Command Prompt type chkdsk x: /r/f ENTER. X being the drive letter.
3 Related Answers
Anonymous
  • 7 Answers
  • Posted on Mar 23, 2009
SOURCE: Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Anonymous
  • 83 Answers
  • Posted on Aug 03, 2010
SOURCE: Sony 1GB Memory Stick PRO Duo Memory Card not
check it with other computer may be problem with OS . So check it
Anonymous
  • 358 Answers
  • Posted on Nov 20, 2009
SOURCE: Sigma card reader/writer doesn't recognize my new SD card
What I suspect here is that, the USB port that you are using is a USB 1.0 port, which has a lower voltage not enough to power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a USB 2.0 one (Just keep Checking all the ports one by one in case you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Hope this helps you out.
Goodluck
Can the Kodak 50 IN 1 card reader be used as a USB to USB connection for tethering a tablet to a phone?
The perfect complement to any digital camera or cell phone! This 50-in-1 card reader is the perfect complement to any digital camera or cell phone that takes compact flash, secure digital, microSD, XD, or Memory Stick, MS PRO, or MS DUO cards. Simply plug the reader into your computer, put your card in the reader, and have full access to all your pictures and other files. It's that simple!
  • Universal Reader/Witer
  • High-speed USB 2.0
  • Mac OS and PC compatible
  • Compatible with all versions of SD/HC/MicroSD/CF/XD & MS/PROP Duo Reader/Writer
  • 1 year mfr. warranty
Compare with similar items
Would you like to give feedback on product content, images, or tell us about a lower price?
SPECIFICATIONS Flash Memory Card Product Type Reader Card Reader & Adapter Type Reader/Writer Card Reader & Adapter Interface USB Card Reader & Adapter Compatibility Mac & PC
My MacBook Pro OS X 10.9.1 won't read my Lexar Professional 800x 8 GB Compact Flash UDMA 7.
Try
http://www.apple.com/macbook-pro/
You most likely will need a different card to be compatible with your MacBook pro. Apple website should be helpful.
You can try using a file recovery software like Bad Copy Pro 4.10.125. It works well for me.
Where do i insert my compact flash
You need to insert your compact flash memory card into an USB CF card reader then plug the card reader into the USB port of your computer. Your computer will detect it as an external storage device then you can open the image folder and copy the photos to your computer.
2helpful
I just inserted a new 8GB memory card but it tells me ''OUT OF MEMORY'' I tried to format it but still gives me the same message. Why is that and what can I do about it please?
The memory card you are trying to use in the camera is not supported. This camera is an older technology that can not recognize the large 8 GB memory capacity of the card. In fact, the largest approved card your camera will recognize is 1 GB.
The list of approved memory cards was obtained from the Nikon Site directly, and pasted below for your convenience.
Nikon has tested the following cards and approved their use in the Coolpix 5700:
CompactFlash memory cards:
SanDisk SDCFB series 16 MB, 32 MB, 48 MB, 64 MB, 96 MB, and 128 MB
Lexar Media 4× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 8× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 10× USB series 128 MB and 160 MB
Lexar Media 40x USB WA series 256 MB*
Microtech International Digital Flash Film 1GB*
Delkin eFilm 650MB Pro*
Ritz Big Print 8x 256MB* (Edge Code 0E1B)
Microdrive cards:
DSCM-10512 512 MB
DSCM-11000 1 GB
Please rate this reply if it helped you out. Good luck!
Professional High-Speed 2GB Secure Digital Memory Card: how do I format my lexar 2 gb memory card for my c...
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
3helpful
In embroidery mode I insert a card adapter into my machine and all I get is a "communication error" I have a Dynex card reader which works fine on my computer. I also have PQ1 compactFlash adapter that...
The solution was sooo easy.....one of my online embroidery groups suggested to put the card in my Janome and let the machine format it. It took about a minute and did not tell me what it was doing..and It worked! It put two folders on my card, Emb5 and ord#5, and I was to copy the jef files into the Emb5 folder, which I did and bingo! my Janome 9500 read the card and produced a screen with my jef files in it. I am a happy camper....I don't know if this works with all Janome machines but it did with mine.
Thanks for being here to help.
Pepsi lady
I have a Canon EOS 350D, Compact Flash card freezes my computer
Instead of connecting via the camera, just use a USB card reader and put the CF card in that.
Copy pic. from cd to card reader
just insert you compact flash card into your card reader and let windows to show under my computer.when you see your flash card under my computer ,enter into your cd and select the pictures files you want to copy to the flash card.Now right click you will see a pop up box ,select sendto > ,now under sendto option you will see your flash drive,just select it and your files will get copy to flash drive.
if you are unable to perform these steps just select the photo files and right click ,then select copy.Now goto your flash drive ,double click on it to open it.Now right click and select paste........that's it. your files will get copy to flash drive.
Top Lexar Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
