Black led failure - Office Equipment & Supplies
  • 3 more comments
  • keithcjr Jan 02, 2009
    I have a black led failure service code U21 I need to be able to order the part and replace it. This is a xerox Phaser 7400DN.
    That URL simply shows how to remanufacture the cartridge I found that site with a google look up myself
    This is a printer not a copy machine the buttons except the pink clear button do not exist
    led = light emitting diode
    The part I am looking for is not shown at that site
    Genius:
  • 1,239 Answers
Hi i think there is a error message comming on .......then it should be replaced
Posted on Jan 02, 2009
  • 55 Answers
All you have to do is turn the power off and unplug the machine for 10 seconds, plug it back in and turn on. Good luck
  • 8,220 Answers
Remove the black ink cartridge. Clean it up and reinstall it. Go to printer toolbox and select CLEAN CARTRIDGE, let it do its thang.
  • Dan Webster
    Dan Webster Jan 02, 2009
    replace or clean the black ink cartridge. If you have refilled this cartridge manually then reinstall it and go into the printer toolbox and set it to clean the cartridge.
    Brigadier General:
  • 5,158 Answers
You can purchase supplies here
http://www.office.xerox.com/printers/color-printers/phaser-7400/supl-enus.html
  • 15,935 Answers
#1 Check the Black LED assembly to properly be installed.
#2 Inspect the wiring harness leading up to the assembly.
#3 Replace the engine controller board
  • 1 more comment
  • blueextc3221
    blueextc3221 Jan 02, 2009
    Troubleshooting Procedure Table
    Steps Actions and Questions Yes No
    1 Cycle power to the printer.
    Does the error still appear?
    Go to step [2]. Complete
    2 Try to isolate the problem LED Head by
    swapping with another LED Head.
    Does the error move with the LED Head?
    Replace the LED
    Head.
    Go to step [3].
    3 Ensure the wiring harness to the LED
    Head is properly connected and not
    damaged, misaligned or crimped.
    Is the wiring harness defective?
    Reconnect or
    replace wiring
    harness.
    Go to step [4].
    4 Check continuity between the Toner
    Sensor Board and the Engine Controller
    Board.
    Is there continuity?
    Replace the
    Engine Controller
    Board.
    Replace the Toner
    Sensor Board
    and/or Wiring
    Harness.
  • blueextc3221
    An LED printer is a recently-developed type of computer printer. LED technology uses a light-emitting diode array as a light source in the printhead. The LED bar pulse-flashes across the entire page width and creates the image on the print drum or belt as it moves past.
    LEDs are more efficient mechanically than conventional laser printers, since they have fewer moving parts. Depending on design, LED printers can have faster rates of print than some laser-based designs, and are generally cheaper to manufacture. Laser systems rely on elaborate combinations of rotating mirrors and lenses that must remain in alignment throughout their use. The laser scans from one end of a line to another, then starts on the next line. Unlike laser printers, the LED printhead is solid-state and has no moving parts.
  • blueextc3221
    The LED im referring to is the CARTRIDGE as you may call it.
  • 10,594 Answers
Here you can have toner cartridge for Xerox 7400 printer.
    President:
  • 2,110 Answers
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
    Novelist:
  • 163 Answers
Please explain your question?
  • ronny2051 Jan 02, 2009
    follow the blow site may be help for u--
    http://agatis.biz/files/Xerox_Phaser_740...
    That is caused by the fuser. There is a solid aluminum roll and a silicon rubber ( pressure) roller in the fuser. The pressure roller either developes some flat spots from park ( non running) time and over time heat and use cause it to deform and become out of round. What then happens is when the paper enters the fuser it does so with a slight twist, and the pressure of the fuser, for lack of a better term, Irons in that crease during the fusing process.
What's wrong with my LG 55LV9500 LED TV? Power on, black screen.
Hello, either the power supply is failing to power up the LED's or the LED strips in the screen have failed, a common issue with these sets. Power supply part # is EAY62169701. LED strips are only available as a complete screen assembly from LG....thanks
Apr 23, 2017 | LG Televison & Video
I have a Sharpe LC-60LE600U. The power went out on it. What power board works on that TV. The lower left hand corner has a black spot, too. Will the power board fix the black spot as well?
Power Board wil not fix black spot. the spot is caused from lamp failure. Led strip has at least one LED out, takes out the whole section. Go into trouble shooting to verify. After so many start ups with the black spot, the TV will not turn on in TV mode.
Sep 22, 2016 | Sharp Aquos Televison & Video
LG tv black screen with sound
Hi Tommy,
This is a common problem with LG LEDs. It is a backlight failure. Either the backlights are not receiving the power to drive them or some of the LEDs in the backlight array have failed.
I hope it helps.
Good Luck.
May 25, 2016 | LG Televison & Video
Blank screen, led lights flashes for a while and thn all three flash. also cannot turn off at tv or with remote. have to unplug
Samsung HL67A750A1F red DLP LED failure repair ...
? 10:35
https://www.youtube.com/watch?v=xHE1knzJSfQ
Jul 21, 2011 - Uploaded by daveshelbygt
Samsung PHLA... ... Samsung HL67A750A1F red DLP LED failure repair .... tv only works when plugged in. black screen, any suggestions?.
HL67A750A1F Blank Screen, And The LED Lights Are On ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsFeb 24, 2011 - Click here if the screen is blank and one or more of the LED lights on the front of the TV are on or are flashing.
Samsung HL67A750A1FXZA Repair Success Stories ...
Jan 19, 2016 | Samsung HL67A750 67 in. TV
Dell inspiron laptop N5040 3 beeps interval 3 beeps black screen
Explain the intervals at which it beeps, either 2 short beeps and a prolonged beep. does the hard disk LED blink? if it does its display inverter problem. if no blink on hdd LED its either RAM or cpu failure.
Oct 04, 2013 | Dell Inspiron Computers & Internet
While trying to boot my IBM R51e Laptop (purchased in 2006), all i got is black screen with only power supply LED "on" (on below monitor side, LEDs notification area), no other LEDs are...
my conclusion is you have a BIOS failure.. that symptoms is typically a BIOS problem. just like mine. bring your laptop to the IBM service center.
Jul 10, 2011 | IBM (10l1433) (  10L1433)...
I have a HP Pavilion tx 2000 tablet pc. When i turn it on the power button it shows that its on. The hard drive light does not flash and the caps lock and the number lock button keeps on blinking. My...
Hi
Boss you need to mention here in what sequence do the lights blink.
Anyways you can take help from this
Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
DO RATE MY SOLUTION
Jul 04, 2011 | Compaq Presario Notebook
89 people viewed this question
jasbo
jasbo
