Question about Kenmore 82822 Electric Dryer
Start button pressed in and now won't start
Kenmore HE2 Electric Dryer-frontload
Model # 110.87562601
The start button was pressed too much or too hard and now it is basiclly stuck in-not letting the dryer start. The power button and everything else works. Please help!!! :)
  • 56 Answers
You should have a tec come by and take a look thats a five min. job the sping insinde probly broke. hope this can help you.
Posted on Jan 05, 2009
Kenmore he2 dryer, model: 110.c87561602 beeps twice, wont start and is not showing any error messages
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jan 03, 2017 | Kenmore Dryers
Kenmore dryer 592-89047 won't start
Sounds like the lint may have fallen into the fan and has jammed it. The motor will hum if that happens. Its an easy job to clean just take your time taking the blower cover off and reverse the process replacing it.
Apr 26, 2012 | Kenmore Dryers
Kenmore HE2 dryer will not start
the relay for the motor is probable stuck recommend service
Jun 03, 2010 | Kenmore 82822 Electric Dryer
82822 / 82824 / 82826 Electric Dryer: kenmore HE2 electric dryer, beeps and all display ...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 17, 2010 | Kenmore 82822 Electric Dryer
Kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Jun 12, 2009 | Kenmore 82822 Electric Dryer
I HAVE A NEW (3 MONTHS) KENMORE HE2 ELECTRIC DRYER MODEL # 110.8756, IT APPEARS THAT I CAN TURN THE POWER ON, SET THE PARAMETERS BUT WHEN I PRESS START I JUST GET A BEEPING SOUND. THE LIGHT ON THE...
because is a 3 month old dryer is better for a technician to give you a diagnostic because can be a manufactory issue.
If you have any question please let me know.
Was this helpful?
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Kenmore 82822 Electric Dryer Logo
534 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
