Question about Philips DVP5140 DVD Player
Won't play My dvd player says "loading" for a while and then "no disc." It used to play these dvds.
  • 7 more comments
  • bzmama Nov 20, 2007
    I have a HTS3400 Phillips DVD that says loading and then No-Disc. Shipped it back to the manufacturer, they said they only cleaned it and there was nothing else wrong. It ran for 1 week and started displaying No Disc again.
  • Anonymous Jan 07, 2008
    Same problem
  • jimmydodger Mar 01, 2008
    The warrenty on mine has ran out so i thought what the hell and took the cover off, the problem is obvious, the motor that spins the disk has packed in so it is loading for an abnormally long time and then displaying no disk.the drive inside has sony written all over it so i am currently trying to find a replacement with no such luck,if anyone can point me in the right direction were to find one of these consumer product dvd drives that would be great.
  • inzeem Mar 11, 2008
    if i put cd means it wil load for few seconds and shows no disk
  • Anonymous Mar 21, 2008
    i thought i had some sort of dvd curse.. this is the second player ive bought that works like a gem for a couple of months and then doesnt work. in this case refusing to read any discs.
  • Anonymous Apr 06, 2008
  • T1mb0 Apr 07, 2008
    I get the "no disc" error too and it worked last week on the same DVD. The thing is 1.5 years old. I opened the case, and cleaned the lens. No better! So I've decided to replace the optical pickup laser or unit as I'm certain it's not working properly. The player seems to seek the disk but can't find it. It must be that! The laser/optical pickup in my DVP-5140/37 has a part number of SF-HD65. It is a Sanyo component and I've tracked down 2 suppliers here in the US. Lots of links to wholesale places in China. One US supplier sells for $12 and the other for $15. With postage it'll be about $20. That's better than buying a new player. I just hope it works......
  • Soma Sundaram G
    Soma Sundaram G Jun 01, 2008
    Philips DVP 3046 - 1.4years old now its showing loading for long time and displays later No disc.
    If it plays some time and suddently get stopped itself.
    Servicing guy saying board problem and charging Half price of the player.
    Any tips to overcome this problem, where to get the firmware/software to upgrade it.
    please suggest me.
  • Anonymous Jun 29, 2008
    NOT GETTING DVD BACKGROUND SCREEN ON TV.DISC IS PLAYING NO PICTURE . THE WORD "ROOT" IS DISPLAYED ON DVD DISPLAY PANE. WAS DOES THIS MEAN?
    CHRISTINE
  • 3 Answers
Fixed it! I got a new laser/optical pickup (SF-HD65) and replaced the old one. Replacing it wasn't too hard, just a little fiddly. Once it got it all back together, I fired up the unit with the case open and could easily see the red glow of the laser through the spinning disk. This didn't happen with the old pickup. Every disk I put in (originals and burnt stuff) was detected.
Even though the new laser worked, I can't be 100% sure the 24 pin ribbon cable / flat flex cable (ffc) connecting the laser to the mainboard isn't dodgy (I didn't try the old laser again). It's very flimsy and I may have somehow managed to re-seat the connectors better or bend the cable enough to make a contact over a break. If I get the "no disc" error again I'll replace that with the same or similar. For all out there it has the following written on it Kotobo E188165 AWM 20798 80C 60V VW-1. It's about 25 cm long, has 24 pins.
Regardless, I'm happy I didn't send the player to landfill. For $15 + shipping, replacing the optical pickup was cheaper than buying a new player that plays as many formats.
T1mb0
Posted on Apr 11, 2008
The quality of the lens is an issue with this very cheap player.
I have to clean the lens about every 6 months as the problems you describe start to occur. Is now a routine for me, takes only 10 minutes ...
  • Remove 6 (only 2 last with mine) screws with the torx
  • remove phillips 2 screws of the plastic 'cd holder bridge'
  • use spiritus to clean the lens
I've tried to clean the infrared LED of the remote to improve performance of that precission instrument; no luck ....
Posted on Jun 06, 2008
Sometimes it will load if I slap the thing the right way. Unplugging and plugging back in worked good for awhile. Won't buy another Phillips.
Posted on Mar 24, 2008
I have the same problem. This dvd player used to paly every DVD's single and double sided, but now 10 months later it won't play anything. I will bring it back to the store since it should still be under warranty
Posted on Oct 12, 2007
My JVC HR-XVC27U plays some DVDs but not others. They have the correct codes, but it seems to not play the newer DVDs like Toy Story 3
see the causes and remedies and fix it: God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Jul 20, 2012 | JVC HR-XVC27U DVD Player/VCR
When i insert a dvds the display keeps flashing loading and won't play the dvds
Clean the optical pickup lens. Use a lens cleaning disc. If it do not help you, replace the optical pickup unit.
May 27, 2012 | Sony Televison & Video
My toshiba BDXK100 won't play DVDs other than Blu-Ray
There may be a issue with the assembly, blu-ray plays with more precision and speed, for some reason it is not slowing down to play the regular DVD's may be a padder motor problem.
Mar 19, 2012 | Toshiba BDX2000 Blu-Ray Player
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Feb 27, 2012 | Sony DVP-NS710H/B DVD Player
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
PS2 will not play DVDs
hEy i hAd the sAme pRob...............dOn wOrRy all u hAv to do is to turn on uR pS2 witthout puttin a DVD oR aNy diSc........on mEnu screen gOto [options] by pRessing 'triangle' button......... a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst.....then insert the DVD movie........tURn off PS2....press n hold the reset button till the blue light is turned on......release the button and press it again.............. it wOuld take a little tYm foR uR DVD movie to be loAded........be patient till the movie plays it self..............
Jun 13, 2009 | Sony PlayStation 2 (PS2) Console
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Home burned DVDs won't load, commercialy produced DVDs load OK
Try using a programme called dvd flick http://www.dvdflick.net/ to author your dvds and use imgburn http://www.imgburn.com/ to burn them. I had similar kind of problem with dvds burned with nero and now use dvd flick and imgburn all the time and have had no problems. They are both free programmes so hopefully they will sort the problem out for you :)
Shaz
Sep 30, 2008 | Philips DVP5140 DVD Player
Philips DVP5140 DVD Player Logo
1,036 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
