Question about Kenmore 63942 Dryer
Kenmore dryer wont heat anymore.
  • Kenmore Master
  • 8,205 Answers
Most likely the heating element however it could be a limit IF you have lint problems. The best thing you could do is break down the dryer and go over it with a vacuum. Ohm out all the safetys and heater. Fairly simple process.Just remember to remove a wire from each component so you won't get a back feed or what we call a false reading.I like to use an ohmeter with an audible continuity reading. (when the 2 leads are joined it beeps) then check each component for a beep. See easy! let me know
Posted on Jan 15, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
KENMORE ELECTRIC DRYER WILL NOT GET HOT ANYMORE
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Kenmore Dryers
Kenmore Dryer does not dry anymore
heatman101;
Jul 22, 2011 | Kenmore Dryers
I have a Kenmore 80 series gas dryer that will not heat up anymore. I took off the small clip in front and can see the heating element start but no flame or heat . Also the dryer will make an intermittent...
check the thermal fuse on the blower housing,if it shows good then possibly the gas valves are weak on the burner tube and wont let gas into the burner
Nov 18, 2010 | Kenmore Dryers
My dryer doesn't have heat anymore, and i already got the new heater but the new heater still doesn't work. Please help.
have you taken the vent hose off and felt to see if it is blowing hot air? Here is a website that has possible solutions to no heat:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 29, 2010 | Kenmore Dryers
Dryer does not have heat up anymore
faulty thermostat These usually sit above, or close to, the heater assembly.You can usually get at this by removing a seperate rear heating duct panel.d9a15dd.jpg this will give you an idea of what your looking for , good luck
Aug 18, 2009 | Kenmore Dryers
My electric Kenmore Dryer (65291) does not get hot anymore
does it still start? if so you may need a ne heat element?
Feb 28, 2009 | Kenmore Dryers
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
Dryer doesnt dry clothes
If your kenmore electric dryer is not heating anymore, the problem can be with the element, with the thermal fuse, or rarely with the control timer , see below from repairclinic: What is wrong with your Dryer?
Oct 15, 2008 | Zanussi TC180W Electric Portable Dryer
Kenmore 63942 Dryer Logo
43 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
