Question about Maytag MMV4205 Microwave Oven
The power went out and resetting per book, only heat doesn't work
The power went out on the microwave and after resetting by unplugging and then power button, the microwave runs but there is no heat.We have lights, and the timer works fine.
  • 1 more comment
  • Dale Snoblen Jan 02, 2009
    1. model MMV405 BAS 110 watts
  • Dale Snoblen Jan 04, 2009
    The turn table starts and the light comes on. It sound kind of like a crackle hum. But not really sure if it is differant than before sound wise. Everything works except there is no heat.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
  • Maytag Master
  • 9,098 Answers
We have a sound clip of what a microwave should sound like when the cooling fan and all are working here.
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
(if it's not shorted or burned, it's probably okay)
Posted on Jan 04, 2009
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
If it powers up but no heat, the magnetron tube went out. Not worth fixing unless under warranty.
Feb 04, 2013 | Microwave Ovens
When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still won't work, then you may have a bad membrane keypad / DP circuit.
If your model is NN-P295SF, the service is here.
Parts can be ordered from Encompass here.
Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
My GE Spacesaver microwave is not power at all.
Usually a Thermal protection (Like Circuit Breaker) this should be tested with Multi Tester. If this open, no Electrical Power goes to the Primary Winding of your High Voltage Transformer and will not power up your magnetron therefore no heat inside the Microwave Oven.
Jul 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The display lights are all solid and nothing happens when you press on the keys. I have a GE Sensor Microwave. I bought it in September of this year. Came home from work one day, went to heat something up...
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
You may have a failed keypad.
Dec 11, 2008 | Microwave Ovens
GE xl 1800 beep
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jul 10, 2008 | GE JVM1660 Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
how do i change the bulb inside the microwave ge xl 1800
Feb 13, 2008 | GE XL1800 1100 Watts Microwave Oven
Maytag MMV4205  Microwave Oven Logo
74 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
