Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
Cd drive opening and closing on its own
The cd drive keeps opening and closing on its own - first it wouln't open i pried it open and then it wouldn't close everytime we closed it manually it would reopen - now it's opening and closing on its own
  • highpraise47 Jan 03, 2009
    that's what i meant when i said pried it open...after searching for solutions, i think i pushed too hard into the pin-hole. is that fixable
  • Anonymous Mar 02, 2009
    I have a HP pavilion and i just turned it on today and the dvd/cd drive keeps on opening and closing for no reason but it only opens part way?
    Master:
  • 461 Answers
You never should have pried it open. Only use the manual eject pin-hole with a paperclip. Noe it seems the drive tray is damaged and will not close properly so it is constantly opening and closing trying to find home. The drive will need replaced.
Posted on Jan 03, 2009
  • Curtis Richner Jan 03, 2009
    It is unlikely it can be fixed without having the drive replaced, however it sounds like it had already been broken prior to you manually ejecting the tray. The optical drive is easily removed on your system (see here). A new drive from Dell is $110. You may also check Ebay for a used or refurb. unit.
The cd player will not open when you press the open close button
unfortunatly the mechanism is jammed up for one reason or the other reason #1 a cd is stuck inside #2 the gear just wore out and or it was forced closed by hand instead of pushing the eject/load button..you can try to gently pry this door open while pressing open/eject button that works 40% of the time..if it does not work? it can then be deemed broken out of order.
it's worth a shot trying to pry it open but beware this could either work or really destroy the door/mech/player comes down to this "do you feel lucky" sadly? that's where we're at with this one.
Mar 20, 2014 | Electro Brand Nostalgic Stereo CD Music...
HI. My Acer Aspire 3500 DVD drawer was I guess off track. The drawer wouldn't open so I pried it open. Now it won't stay shut and when it is shut I can't open it unless I use a paper clip.
There is very little you can, these items in general cannot be repaired. Go to www.ebay.com Type make and model of laptop, refine search to cd/dvd driver.
Jun 12, 2012 | Computers & Internet
The cd door on my dell computer model #: IN1910N keeps poping open. everytime i turn on computer it opens. then i close it and wont stop poping open
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
dont forget to vote
Feb 25, 2011 | Dell Computers & Internet
My CDROM drive keeps opening and closing randomly. I have tried disabling it in Device Mgr, but it still is opening and closing. I also uninstalled it in Device Mgr, but still it won't stop opening and...
Do you actually use the CDROM drive?
I assume no because you say you keep trying to disable/uninstall it- If this is the case, just unplug the power cord from the back of the drive.
Only thing I can think of that would cause this is a faulty/intermittent connection inside the CD Drive, which could only feasibly be fixed by replacing it. They're like $12 these days.
Jan 11, 2011 | Artec WSM-52X-UR CD-RW Burner
I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Dan
Feb 23, 2010 | Aiwa Audio Players & Recorders
My xbox 360 keeps saying reading reading reading then says open tray what do i do
okay that sounds like the magnet in the cd case is stuck.open your xbox360 and access your cd drive.search on the internet if u cant.when you do,on the drive there is a circle pry it off with a flathead screwdriver and you should see a circle looking thing that moves around freely when you move it.okay cut out a circular piece of index card or thick paper that could fit on the circle and place the big metal circle you pryed off back on the drive.reassemble the xbox.it should read now.if that doesnt work then it could be the placement of the laser.dissassemble your xbox again or do this also before you reassembled it.open your cd drive by removing the 4 screws holding it together.{if its a hitachi lite(H-L} drive it will be 6} and remove the top cover there should be a lense thing that moves back and forth when it reads the games move it as close as you can to the {spinner} make sure there is no dust or hair on the rails and reassemle your xbox360.there ya go.oh if you here a buzz when u play the game dont worry about it its not gonna blow up lol.
Dec 22, 2009 | Microsoft Xbox 360 Console
Dvd/cd drive door keeps opening and closing by itself
If the trouble isn't being caused by some screwy virus or software problem, the best solution is to replace the drive. New drives are quite inexpensive and widely available in retail stores (at higher prices) and online.
May 27, 2009 | HP (D4384-63002) (d438463002) Internal 32x...
CD Rom Drive opens and closes over and over won't quit
it happens often because of some materials or cd broken pcs try to clean it carefully
Apr 11, 2009 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
DVD tray wont close
Hi , reset the computer try to open dvd and okey if not try to check belt it visible near the cd tray if still align with the pulley.
Jan 31, 2008 | Bose 3·2·1 II System
Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
672 people viewed this question
Alun Cox
