Question about Kenmore 24032\24036 Top Load Washer
Won't start, cover activated switch is down
The switch that activates the machine is in a "down" position, meaning that even if you open/close the cover, it doesn't engage the switch.
    Novelist:
  • 148 Answers
This is a tricky problem the switch mount has come loose
FIX
1 unplug the machine from the wall
2 take your fingers and slide them up under the lip of the housing of the washing machine where the switch is down
3 once you have located the switch modue under the lip slowly squeeze your fingers to see if the housing moves the switch up
4 when you feel the module move up and you are still holding it up take a small flat blade screw driver in your other hand and put it in the slot to push the actuator down listen for a click
5 if you hear it click then the switch is ok it just needs the mounts tightened
6 To tighten the switch body, force the tub in the opposite direction of the switch by pushing the top of the agitator .
7 Using a flashlight find the screws holding the switch body and tighten
8 If the body is tight use the flat head screw drive to se if the switch clicks if so you are ready to test if you do not hear the click you will need to bend the metal actuator lever up slightly nutil you hear the click
9 Pulg the washer in , turn on , close the door and you should be read to wash!
10 If this does not work, remove the switch module and take to apliance repair supply and replace
BEST OF LUCK TO YOU!
Posted on Jan 03, 2009
I can't find the fuse for the power windows on a 1998 Lincoln Navigator
All the other windows work ? Not a fuse , one fuse powers all the windows . Test for B+ voltage at the switch an the window regulator would be the proper diagnostic procedure . Do you own a volt meter ? know how to read a wiring diagram ? how to do basic automotive electrical testing . The Faint click you hear is probably a relay , which means the GEM - genaric electronic modual is energizing the window relay . The windows are computer controlled .
The GEM will activate the OTD Relay until one of the following conditions is met:
  • The LF regulator control switch is pushed to the UP position.
  • The LF regulator control switch is released (OFF position) and then moved to the down position (first detent) or one touch down (OTD) position (second detent).
  • Seven seconds have elapsed since the OTD was initiated.
  • A window regulator electric drive stall condition is detected on the one touch down sense line inputs.
The UP window operation is not controlled by the GEM. The feature is activated when the delayed accessory is active and the LF window regulator control switch is pressed to the UP position. The switch provides delayed accessory power to one side of the motor and ground to the other side through the one touch down relay. The one touch down relay is not active when the LF regulator control switch is in the UP position.
Passenger windows may be raised or lowered using the LF master control switches or the appropriate passenger window switch. Passenger window switches receive power when the delayed accessory relay is active and the LF remote lock-out switch is in the UNLOCK position. When in the LOCK-OUT position, the passenger windows are deactivated.
The GEM controls manual down and auto down window movement with the down window relay. The relay is activated by applying ground directly to one side of the down window relay coil, and deactivated by removing the ground signal.
The delayed accessory relay provides power for the operation of the power windows and the power moon roof. The delayed accessory feature is active when the ignition switch is in the RUN or the ACC position, or when the ignition switch is changed from RUN or ACC to the OFF/LOCK position and the LF and RF doors are closed.
The GEM will deactivate the delayed accessory feature when:
  • the LF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • the RF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • 10 minutes have elapsed since the ignition switch was changed from ACC or RUN to the OFF/LOCK position.
Feature inputs:
  • LF door open warning switch (open circuit with door closed, grounded with door ajar).
  • RF door open warning switch (open circuit with door closed, grounded with door ajar).
  • Ignition switch RUN position (battery potential on both the RUN and RUN/ACC inputs).
  • Ignition switch ACC position (battery potential on the RUN/ACC input).
  • Ignition switch OFF/LOCK position (absence of battery potential on the RUN, RUN/ACC, and START inputs).
The Trainer 24 Power Window Troubleshooting
Mar 03, 2017 | 1998 Lincoln Navigator
Machine shows E 61 when switch on.
E61 I think this a door lock error code. When you close, the door it activates a switch which will allow the machine to start a wash programme. Conversely the first thing the selected programme does is activate a solenoid, to stop you opening the door before the machine is ready. Think spinning drums, small children and cats, or flooded floors. I digress, if that little switch stops working or the mechanism has moved slightly and isn't activated, the machine assumes the door is open.
Maybe not a great help but we have narrowed things down.
H
Apr 03, 2016 | Washing Machines
Front cover is on alarm even the front cover is already closed. how can i reset the alarm.
Hello, Did the technician ask about any error codes in display?
For Example the number 2 from the center picture on display ( the picture of machine) or by pressing and holding the * (star) key on number pad show 2 numbers with the second being 817 in the red number area?
When the door is closed there is a one inch thin piece that gets inserted into a slot that activates a switch proving the door is closed..
There several resets you can try - holding down reset while powering on machine, Holding down just the "print position" left and right arrow keys (not the center) . and powering on equipment then typing "94" and then press start key. Note press clear if any numbers show up before hand.
If no results the part on door has broken or the switch is out of position to activate correctly,
Please tell any codes and we can go from there. TY
Jan 29, 2015 | Riso RZ220 MASTER UNIT - ONE ROLL PACK
The down adjustment broke off
Check the micro switch that will be activated when the door reaches the closed position. It might need to be readjusted as it is supposed to be activated just as the door reaches the fully closed position to stop the further movement of the door. If it does not get activated at that point the door will try to open further but sence an "obstruction" and start opening again as a buildt in safety measure for protection against possible injury or damage to property.
Jul 23, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
My washer has been stopping mid-cycle like the lid was opened lately. I have been able to open and close the lid to "jar" it into finishing the cycle(rinsing) until now. It has just stopped and...
The lid switch will need a slight adjustment to properly activate, or you could bend the raised bump on the back of the lid out a bit so it activates the switch better.
Jul 27, 2011 | Maytag Washing Machines
Top cover open error when printing
I had the same problem and fixed it by sticking the end of a pen (the writing part) in the hole on the right side when you open the top cover.
In other words if you open the top cover and look on the top cover you will see a tab that goes into a hole(the hole is next to the picture of the print cartridges). There is a hole with switch/tab(I don't know the proper terminology) on it that is activated when you close the top cover. If you stick the end of a pen in that hole it should activate something and the print cartridges will start to make noise and move around. You can then close the cover and it should close all the way.
You can then try to print a test page.
Good Luck
Dec 13, 2008 | HP DeskJet 5650 InkJet Printer
Help
one ot the doors, most likely the one on the right is not closed, there is a sensor switch there it is not being activated, make sure all levers are in he correct positions so the doors can close evenly.
Jul 23, 2008 | Brother DCP 7010 Multifunction Laser...
"Lower presser foot" error on SE 270D
This happened to me and I eventually realized that there is a small door flap at the top near the "4" in the threading series that can get stuck open. Normally this flap goes up and down with the presser foot, but if it gets stuck open even when the presser foot is down, tapping it or closing it manually will make the error go away.1_9_2012_12_19_55_am.jpg
Dec 28, 2007 | Brother SE-270D Computerized Sewing...
Lens Cover Closed
the switch inside that activates the camera is probably loose, or worse, broken.
Sep 09, 2006 | Sony DSC-T7 Digital Camera
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
