Question about HP PSC 1610 All-In-One InkJet Printer
Hi I have HP PSC1610 printer-copier-scanner. 90% of all my printing I do in "FastDraft" Paper Quality. The default is in "Normal" Paper Quality and I have to change the settings each time I print. I would like to change the default to "FastDraft" Can anyone please help? Dennis--
  • dwood0 Jan 02, 2009
    Thank you very much, your solution did the trick. --thanks again
    Dennis--
    Scholar:
  • 82 Answers
When you print from the Microsoft Word and while printing you change the Printer Properties and Print Quality to FastDraft
Everytime you close the window the setting gets reset and again when you start, you have to do the settings.
The Solution you are looking out is
Go to Start >> Control Panel >> Printer and Faxes
There you choose the your Default Printer HP 1610 >> Right Click
and Click Properties
Then you choose Printing Preferences and Make Choose FastDraft
This setting will remain as your default setting now
So whne you have to Print Normal Mode
You need to change the Properties from Microsoft Word.
and it will reset everytime you close MS Word.
Cause your Default setting then is "FastDraft"
I hope this solves your problem
all the best
Posted on Jan 02, 2009
Hp m3035 won't print page comes out warm but no toner
Load paper in tray 1. Print a few pages, as it's printing open the top cover, remove the toner, look at the paper in the printer. Does it have printing on it? If it does, the laser/scanner is working. It could be the transfer roller, it could be Hi Voltage Power Supply. Look in Print Quality Menu/Toner Density. Increase the density.
Mar 10, 2010 | HP LaserJet M3035 MFP Printer
Changing print quality preference
On Windows at least, the print dialog box usually has a "Properties..." button next to where you select your printer. From there, you should be able to choose a lower print quality (Mine gives the options, "FastDraft," "Normal", and "Best"). The lower print quality doesn't look -quite- as nice, but it uses much less ink and takes less time to print as well.
Feb 16, 2010 | HP PhotoSmart C4280 Laser Printer
920c is printing very slow, like 1 copy in 5
it is possible that your printer settings is set print high quality for a photo paper. try to check if you are printing on plain paper, select paper type as plain paper and quality to normal.
Nov 06, 2009 | HP DeskJet 920c InkJet Printer
Paper size
Okay, go to your printer folder Start/Printers Right click on your printer (Officejet 6310) and click on Properties. You will see a button near the bottom called Printing Preferences. Here is where you choose your paper. You can make your choice here and choose to make it your default settings (click Apply to make the new paper your default to print your invitations...you will have to change back after). You may change the quality of print and paper type as well since the default setting won't provide the quality of print you desire. From here it's pretty straight forward. Feed your invitations into the paper tray as you would normal paper and try a test print for quality control. Once you've got the desired output, print the rest of your invitations.
Apr 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Noise when beginning to print or copy
Mine always makes noise too, I don't know why. But I know that it's a lot noisier when paper quality is set for draft, so you might want to check that.
If you just go into the printer properties, under the tab that's something like Paper/Quality. There will be a drop-down list where you can choose the quality of your print out, i.e. Best, Normal, Draft or FastDraft. If it's set for Draft, you might want to change it to Normal. Draft uses less ink, but it also doesn't come out quite as clear, and is very loud.
Mar 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
HELLO...WE HAVE AN HP PSC 950 PRINTER, COPIER, SCANNER , FAX AND IT PRINTS SUPER SLOW...THIS HAPPENED BEFORE AND I PUSHED A BUTTON TO CORRECT THE PROBLEM BUT IM NOT HAVING THE SAME LUCK THIS TIME...HELP!!
I would seem the quality is set to high instead of normal or draft (even faster). Right-click on the printer in the Printers and Faxes folder and select Properties. Under Printing Preferences you can set the default quality. When printing photos you can override this setting.
Dec 30, 2008 | HP PSC 950 All-In-One InkJet Printer
Hp deskjet d2360
Hi
Yes the HP Deskjet D2360 will print pics. If you want to print photo quality, make sure your ink cartridges are in good shape and obtain photo quality paper.
You can actually print pictures on almost all printer paper but if you want a good result, I would suggest you look online for inkjet photo A4 photo paper.
Paper can be obtained in a number of finishes. For example Glossy, Silk, Matt and so on. If you just want reasonable quality for a school project or something, then a good quality non photo paper may be good enough for you.
Paper also comes in different thickness or weights. This is determined by the paper's GSM. For example: 80gsm is normal photocopier paper. A good quality photo paper would be 140gsm or 160gsm. When looking for paper online you'll see the GSM shown. It really is your personal choice. There are heaps of suppliers on the internet. Amazon do a good range.
You can also set your printer for various levels of quality. A rule of thumb is, the bettter the quality, the more ink you will use.
If you want to find out more about your printer, visit http.www.hp.com then look for your particular model.
Hope this helps.
Jan 29, 2008 | HP Deskjet D2360 InkJet Printer
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Hope this helps.
Jan 05, 2008 | HP Photosmart 2610 All-In-One InkJet...
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
HP PSC 1610 All-In-One InkJet Printer Logo
158 people viewed this question
Ben Johnson
