Question about Whirlpool 24 in. DU920PW Built-In Dishwasher
Black stuff in the bottom of the dishwasher
Last night I opened our Whirlpool DU920PFGT4 dishwasher after it was done and found black and grey "stuff" on the bottom. I started to wipe it up and found big black chunks wedged up below the door. It didn't look like part of a gasket or rubber. None of it stuck to the dishes. It didn't smell bad (like old food). A lot of the pieces came out of an indent on the bottom of the inside of the door, but again, they were irregularly shaped and didn't seem like part of a gasket. Thanks
  • Linda Buhman May 14, 2007
    Thanks! I'm glad it wasn't a gasket, but am embarassed that I didn't keep my dw cleaner (who knew you have to wash your dishwasher!).
  • 5,911 Answers
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
Posted on May 12, 2007
How do I unplug a blocked pipe that runs into my smeg dishwasher
You can dismantle any that that screws on or clamps on. Check the pump and the hose out of the pump for blockages as those are the most likely suspects..
Jul 25, 2018 | Smeg Dishwashers
Whirlpool dishwasher adg7560 troubleshooting The
> broken wire.
>> call the service agent
Oct 17, 2013 | Dishwashers
Whirlpool gold 4.0 cubit ft. bought 12-18 months ago. with in the last 2 months (not every load) clothes are coming out "eaten". rips and tears, grey streaks, black streaks, etc. thought maybe...
Rearl633, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Rearl633), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Black stuff in bottom and won't drain, used draino still did'n t drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 16, 2010 | Whirlpool 24 in. DU920PW Built-In...
I have a GU1200XTKQ0 Whirlpool Gold Dishwasher. I
If you have a Wet/Dry Vacuum, then you can use that to **** up any debris you see in the bottom of the Dishwasher. Make sure you remove the paper filter from the vacuum so it does not get damaged from the water in the bottom of the Dishwasher. I use the vacuum trick to clean up the muck from the pump area and it works well.
Apr 04, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Clean light flashes constanly. Won't clear out to start new cycle
I can't get the light to clear off. I can "cancel" and it goes through the drain cycle, but when done after opening the door to reload, then trying to start, it does nothing.
Nov 15, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag model mdbtt70aww. After the end cycle. open the door and found detergent tab on the bottom and the main wash cover is opened. Maytag diswasher model MDBTT70AWW. Put dishes and so...
Check both arms are spinning freely when you have the machine loaded up normally.
If thats ok you could try powder instead of tabs if they are not disolving correctly
Apr 05, 2017 | Dishwashers
Whirlpool 24 in. DU920PW Built-In Dishwasher Logo
2,760 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
