Question about Philips DVD625 DVD Player
Unlock region code for Philips DVP 3256
How can I unlock the region code for Philips DVP 3256?
  • 1 more comment
  • pradipb123 Jan 07, 2009
    Thanks. It works.
  • bpt_gopalan Mar 01, 2009
    un lock phlips dvd player 3268
  • vrat_pan May 16, 2009
    unlock region code for philips Dvp 3256
  • 8 Answers
Region code hack for PHILIPS 3256 x/94
1. Go to Setup. [from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
Posted on Jan 07, 2009
  • subu77 Jan 01, 2012
    wow! Worked like a charm!!!!!!
    Thank you!!!!!!!!!!!
It worked for me, one DVD Kamasutra was showing error due to Region code, really it works, on my broand new Philips DVP3326.
Thanks Buddy!
Posted on Feb 21, 2010
It worked for me after I unplugged the player from the power source and connected again.
Posted on Oct 12, 2009
Philips dvp 2850/79
It is not possible to unlock region codes. Most DVD (blue ray players) allow you to change the region code you can play, once. You can't even switch back to the original code it was set when you bought it.
If you really want to play disks, the only way to get around this, to rip the disc on a computer, and burn it on the computer, region free. For that you need special program m's, but in some countries you can get these programs for free.
Or buy several players, each set to a different region.
Sep 16, 2014 | Televison & Video
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
DVD dvp 3120 is currently zone 4. Would like to make it multi zone
1) Go to Setup page
2) Preference page
3) Press 138931
4) Press up/down key to select region code
Sep 13, 2008 | Philips DVP5140 DVD Player
Unlock region code
Keep Tray in eject position
Press Setup from remot
Go to preference page
Press"138931"
Using Navigation Key chane region code to "0"
Press "OK"
OR
open tray
press 98790
Jun 25, 2008 | Philips DVP3040 DVD Player
Philips DVD Player DVP 3026 set for Region 5 - Unlock code
1) Open the tray
2) Press SETUP on the remote.
3) Navigate to PREFERENCE menu
4) Go to PBC
5) Get in inside PBC menu so that ON is highlighted with yellow color
6) Key in 138931 and a menu will appear asking you to select region code.
7) Select REGION 0.
Jun 17, 2008 | Televison & Video
Unlock region codes
Hi All,
I am looking for the region unlock code for a Sony portable
DVD player.Model number DVP-FX720
Jan 12, 2008 | Insignia NS-PDVD8 Portable DVD Player
Region Free Code: Philips DVP 5980
this worked perfectly, thank you!
Dec 19, 2007 | Televison & Video
Region codes
Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
REGARDING UNLOCKING OF DVP 3028 REGION CODE C1
1st: Start the DVD player, make sure there is no CD/DVD inside.
2nd: Bring up the System Menu.
3rd: Go to Preferences, press 138931.
4th: Use the Up/Down arrow keys to select the region 0 .
5th: Exit the screen.
You can now play DVDs of any region. Enjoy!
Dec 01, 2007 | Samsung Blackjack SGH-I607 Smartphone
Philips DVD625 DVD Player Logo
2,763 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
